What is a mark? It is not a unit of measure found in or on my car. OK, maybe not really. My dipstick has a high mark and a low mark which is about a quart. I can drive 10,000 plus miles between oil changes and I do not have to add oil. I drive on the highway at legal speeds almost every time I drive the car.
If the drain hose was 6 inches long and you had the tube filled up it is not a big deal. The Provent itself has a few cups of capacity internal. Sometimes the Provent collects lots of oil. Other times not so much. Do the math. 6XPiRsquared is what? 1.18 cubic inches. multiply by .55411 (Pocket Ref by Thomas J. Glover, Sequoia Publishing) to figure out how many ounces that is. Not much oil in that 6" tube.
Blowby is not measured by the amount of oil your Provent collects. Nor is it measured by the amount of oil your car consumes.
Have you ever gone to the racetrack and watched a road race with boxer engined Porsche race cars? They burn oil a fair bit. I bet when they are driven at 70 mph with cooler oil they consume less oil. A friend had a delivery truck that would burn oil like crazy when his employees drove it at 80 mph loaded with a few tons of materials. When driven at a legal speed limit the oil consumption went down. 70 mph is not that fast or hard for a VW unless you are carrying a lot of luggage on the top of the car or towing a brick shaped trailer.
The crankcase vent system works on a venturi principle I think. More air into the engine intake causes greater potential flow from crankcase vent. Oil cover and the hockey puck (on my car) restrict the amount of air flow to a degree. I suspect if you hooked a vacuum guage up between the valve cover and the Provent you might not even get a reading.
If you are trying to say you used 1.5 quarts of oil on a 500 mile trip then you have something to worry about. If you are saying you used 3 ounces then you are worrying about nothing.
I can camp for a week with a 50 pound bag that has my tent, bag, clothes and sleeping pad. Add some groceries and a cooler and you should only have a 100 pounds of crap unless you are bringing the kitchen sink. OK, the big Coleman cook stove is 20 pounds with fuel som maybe 120 pounds of junk.
squebel said:
Did a 500 mile trip this weekend. Mostly highway miles with the a/c on and temperatures in the mid 80's. With the seats folded down the car was pretty heavily loaded with camping gear and coolers full of food and beverage. Left the house and oil level was near the top of the dotted lines. I am at 88K and therefore 8K miles in on this oil and I've already added about 1 quart. I also have a Provent with about 6 inches of tubing off the bottom which was emptied before I left.
After the 500 mile trip averaging about 70mph, the oil level dropped a few marks on the dipstick and the tube off the Provent was nearly full. This is much more consumption and blowby than I typically see. Are there any issues I should be checking for? I fear if I had gone another 500 miles I would have been looking at dumping the tube and adding more oil... not good! I've never done an oil analysis but plan on doing one this time around.
Any ideas?
