diesel300dmanual
- Joined
- Dec 16, 2004
- TDI
- Jetta, 1999, Silver
After searching and reading a number of posts, I've determined that my issue (new to me, B4V from Florida, now in Michigan) is the deterioting foam (blowing through vents and NO HEAT, only warm). Blend door problem.
I replaced the thermostat a month ago, fixing all coolant leaks and the engine heat jumps right to 190, as it should. But a long trip to Chicago last night (200 miles) yielded only lukewarm air. And winter hasn't even started yet.
Questions:
1. Can I go up through the floor vents? Someone aluded to that
2. Any other suggestions other than ripping into the dash, heater core, etc?
Diesel Don
Questions:
Diesel Don
