Old July 12th, 2007, 16:12   #1
PDJetta
PDJetta's Avatar
Default Injection Pump Sprocket New Bolt Torque?
I'm replacing the timing belt on an ALH engine TDI this weekend. I have the Dieselgeek "Delux" kit with the needed new bolts, including for the injection pump sprocket. What are the new IP sprocket bolts torqued to? I just read the timing belt "How to" and did not see this mentioned. I take it that the new bolts are not "torque-to-yield" and thus do not require the last "1/4 turn". Is this correct? Also, after the initial tightening of these bolts, I then check the timing with VAG-COM. I can loosen these bolts (reuse them) multiple times correct, since they are not torque to yield, in order to fine tune the timing, right?
Thanks.
--Nate
Old July 12th, 2007, 16:20   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
I don't know the answer to the torque question right now, but will check my manual tonight.
I do think they are tty bolts. The procedure is to do the VAG-COM tuning with the old bolts, then lock the IP pulley down by replacing with the new one at a time.
edit: My B4 manual says 18 ft-lbs. I'll bet the A4 is the same but will check.
-tom
autos: 15 Volvo V60, 14 BMW 535d xDrive
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old July 12th, 2007, 19:01   #4
tongboy
tongboy's Avatar
Fuel Economy: great and surprisingly not bad, depending on which car
TTY is 15 + 1/4
new ones are 18
tongboy is offline   Reply With Quote
Old July 13th, 2007, 05:55   #5
PDJetta
PDJetta's Avatar
Thanks everyone
--Nate
Page generated in 0.14475 seconds with 10 queries
[Output: 66.12 Kb. compressed to 57.95 Kb. by saving 8.17 Kb. (12.35%)]
