BanzaiRider
Hum, after reading the article below I'm a bit confused. My technical knowledge is quite limited but from what I could understand up to now, the new Jetta will be using a particulate filter, unlike the Passat which will have another system called BlueMotion.
Now, if the Jetta has a particulate filter, will it be like what is described in the article? Will be have to go through a cycle every tank and run the engine above a certain speed for 20 minutes min to burn the bad stuff? Man, this is not too good if it's true!
http://www.canadiandriver.com/articles/jk/070509.htm
Thanks for helping me understand all this.
