higgledy
What exactly is a vagcom and how is it different than a code reader the guy at Auto Zone uses to read a code? Do I need to buy one?
BTW I see you are in MD, I work in Reston, VA not sure where you work but I'd be willing to show you how it works sometime during lunch hour if it worked out, PM me some time.....What exactly is a vagcom and how is it different than a code reader the guy at Auto Zone uses to read a code? Do I need to buy one?
Not exactly. The license is in the cable. However, in order to be eligible for direct tech support from Ross-Tech or to be eligible for cable upgrades, you must be the registered owner of the interface cable. Transferring the registration costs $99. If you do not need to upgrade the interface (to a HEX+CAN) and you do not need direct support from Ross-Tech, registration is not required.^^I'm not an expert, but I think you still have to pay for a license if you buy a used cable.
Higgledy may not know why this is important...With it you can also do things like prime the electric fuel pump (s) when changing the fuel filter.
I have not listed mine since I'm uncomfortable with playing around at this level in someone else's car. I have helped one coworker and know of others at work that I could help. At least then it's easier to fix a problem I may have created.I'll mention that to any of you who own one and like helping people out, you would be doing a real public service by submitting your info to the VCDS locator map, especially if you're in an area that's less populated or doesn't have a ton of entries. As soon as I get mine it's one of the first things I plan on doing, there's only one other person on there within 50 miles of me and he never answers any emails I can't tell you how many times I've been in need of a VAG-COM and wished that there were more people on that thing...
Thank you for the clarification Don! I knew there was something. I've seen many times when people contacted Ross-Tech and received help, so that's a good thing for sure.Not exactly. The license is in the cable. However, in order to be eligible for direct tech support from Ross-Tech or to be eligible for cable upgrades, you must be the registered owner of the interface cable. Transferring the registration costs $99. If you do not need to upgrade the interface (to a HEX+CAN) and you do not need direct support from Ross-Tech, registration is not required.
Have Fun!
Don
No you don't actually need VCDS. If you are like most folks, you won't even understand what it does compared to a generic OBD2 scanner.
If you want to actually understand what VCDS can tell you, then VCDS would be indispensable. Using VCDS to it's capability requires that you educate yourself on how a modern digitally controlled car functions.
sent pmBTW I see you are in MD, I work in Reston, VA not sure where you work but I'd be willing to show you how it works sometime during lunch hour if it worked out, PM me some time.....
I do get over to MD sometimes but not real often, OTOH if you live close to Chuck Levins (it's a famous music store) that might give me an excuse to go over there
Analogeezer
I thought all diesels had to have there fuel line primed to rid air from the line. Where is the fuel pump in my TDI? I am assuming it is in the tank like modern gas autos. The filter is in the engine compartment...correct?Higgledy may not know why this is important...
Air in the fuel filter holder/cannister should be purged (using VAG-COM) before you start your TDI after fuel filter replacement. This is a remarkably simple operation with VAG-COM, but it ensures that your fuel pump will have fuel ALWAYS in contact with the pump serfaces. This extends HPFP life expectancy (or at least prevents premature damage/failure).
Yes, there are many other things you can tweak/adjust, and it is exceptionally useful for diagnosing problems when your TDI throws codes at you.
Then again, if you have no time, or are not willing to dig into it, just pay a mechanic instead.
Your TDI has three fuel pumps. One is in the tank, then another (Aux Fuel Pump) is under the hood. These 2 pumps are electrically driven. Then you have an HPFP (High Pressure Fuel Pump) that is driven by your timing belt. The 2 electric pumps can be run with VCDS to prime the system. the fuel filter is in the engine compartment.I thought all diesels had to have there fuel line primed to rid air from the line. Where is the fuel pump in my TDI? I am assuming it is in the tank like modern gas autos. The filter is in the engine compartment...correct?
I was in the dealer yesterday for warranty work. I overheard the service people talking about a customer whose wife filled his brand new Passat TDI with gas and ran the car for a good distance. He was looking at a minimum $7500 repair. Ouch.
