Guys, I'm new here and I'm looking for my first TDi. Was looking for a 2002-2003 Jetta (conventional wisdom, I guess) but was recently convinced to check out 2005.5-2006ish Jetta if I'm aware of the cam shaft issues on the BRM engines.
Well I found a Volkswagen dealer selling a 2006 manual Tdi, leather heated seats, sunroof, for $2000. Has Carfax history that reports cam shaft repair/replace at the 86,000 mile mark. Service seems to be pretty regular but it has 226,000 miles on it. It definitely needs some cosmetic work with some bubbling around a couple wheel wells and some surface rust on the door edge. So'll need a paint job. There's also a rip in the driver seat.
I test drove it and it seems okay but I've never driven a TDi so I can't compare.
So my question is, at $2000 is that a good deal or should I avoid it? I was expected to pay up to $4500 for my first one and I could use the $2500 balance for anymore repairs. What would you do, buy or run away! (The salesman said he could knock a couple hundred off and sell it for $1800.)
