milehighassassin said:
I disagree. Pressure is pressure. At elevation there is less atmosphere pressure.
Example:
My tires have 40 lbs of pressure in them. Really they have 40 lbs + atmosphere pressure (at sea level that is 14.7 lbs). But you cannot read that pressure on a tire gauge because that pressure also exists on the OUTSIDE of the tire as well as the inside.
Today scangauge told me at idle Manifold pressure was 10.8 in Silverthorn. In Fort Collins it read 12.5
So there is some change but the gauge is not off. It reads zero when there is no pressure. Like I mentioned earlier I have another gauge from an old gas turbo which has vac and it always read zero (no vac) when off (under idle on a gasser you are in vacuum). MY gauge is usually VERY close to what I read with vag-Com or scangauge.
1 BAR is always 1 BAR, while the number might change depending on both elevation and weather (that is how a barometer works).
The biggest problem I see is that at sea level the turbo already has 14.7 PSI "helping" it. Today I only had aprox. 11 PSI "helping" my turbo. Really that is just the ZERO point. The gauge is not off because everything else around the gauge is only experiencing that BAR as well. Pressurized systems will equalize. To make 22 PSI at my elevation compared to sea level the turbo has to compensate and make an additional 3.7 PSI. Now the turbo is NOT boosting to 25.7
It just has to work harder.
Pressure is pressure, it is just harder to make it higher up.
I hope this is making sense, I know I am all over the place and this is not well written.
The reason there is less pressure is because you have less atmosphere pushing down on you (in this case 9,000 feet less of atmosphere). This is the same reason it is harder for a human to breath at elevation. In order to inhale your lungs need to fill up with air. At elevation there is less pressure pushing that air into your lungs. It is exactly the same thing with a turbo. There is less atmosphere pushing air into the turbo at 9k feet than sea level. If you were to go to Death Valley and you were below sea level you would have more pressure (BAR).
I guess I wasn't clear. You're right pressure is pressure; but that wasn't what I was talking about. I was talking about differential pressure. Let me rephrase my point and use the term
absolute pressure.
In terms of a pressure gauge reading zero when there is no pressure applied to it's input, you are absolutely right. But, if you used a laboratory grade pressure gauge and went to sea level and filled your tires to 40psi, and then drove to 6000ft and let the tires cool overnight the pressure would be higher in the tires because the atmospheric pressure at 6000ft is less than it is at sea level.
I didn't mean to offend you and say your gauge was actually wrong, I meant relative to your elevation, your scale isn't accurate and here is why:
like you stated atmospheric pressure at sea level is 14.7psi, that's right. And, atmospheric pressure at 6000ft is 12.7psi approximately, right?
So if you use Vag Com on your car and it reads MAP is 2400 millibar at sea level, then you subtract 1000 milibar, then your
absolute manifold pressure is 1400 milibar or 20.58psi, right?
But here's the kicker: if your MAP reading is 2400 millibar at 6000ft and you subtract 795 from 2400, that leaves an
absolute pressure of 1605 millibar.
Therefore 1605 divided by 68 equals 23.6 psi, even though your pressure gauge is only reading 20.5psi.
I'm not trying to start a war here, and I may very well be wrong. But if i'm not, I hope you have a bullet proof turbo.
