mrmoto35
As you know I am a newbie to diesel mods and you guys have always been great help. I know there is no better place to ask this so here I go.
I am getting ready to start ordering parts and I want to be sure I do this right. The specialist I had helping me is now out of the picture. He had his life turned upside down by an ex-wife so I am on my own. Here is where I am.
2013 Passat TDI NMS CKRA. The 6-speed DSG auto trans has been hardened and has a tune. No rev limiter, launch control, traction control on/off button etc etc.
I have in my possession
GTB2260VK turbo with the vacuum actuator mod completed
aFe 2.5 Cat-Back
Neuspeed Discharge Pipe
Going to order
Darkside GTB Turbo Kit for 2.0 16v Common Rail Engines - No turbo option
https://www.darksidedevelopments.co...kit-for-2-0-16v-common-rail-engines-2011.html
Darkside 2.0 16v TDI PD, PPD and CR EGR Delete/Race Pipe
https://www.darksidedevelopments.co...v-tdi-pd-ppd-and-cr-egr-delete-race-pipe.html
4 BAR MAP Manifold Pressure Sensor - Will work with Darkside to get the exact model needed
Oil Return Fitting and Gasket for turbo
Exhaust Studs for turbo
Mityvac Vacuum Testing Tool
So from here I am hoping you can help me fill the gap. I am sure I have missed other parts I will need to complete this
Do I need to add in Intercooler for this configuration such as this? https://www.darksidedevelopments.co...audi-s3-intercooler-with-alloy-end-tanks.html
Would an Front Mounted Engine Oil Cooler Kit such as this be wise/prudent? https://www.darksidedevelopments.co...0-tdi-oval-port-common-rail-engines-2011.html
Thank you all immensely for your help. As always I am forever grateful for your guidance!!
aFe 2.5 Cat-Back
Going to order
