2016, January 30 GTG at DanG144's Chapin, SC
Mrtrouble
Benson,NC
06 Jetta Pkg 2
Hello i am new to this forum but not Diesels had 2 Dodges with cummins my personal truck was an 01 dually converted to single axle running 400hp at the wheels and 780 torque. I am in sales now and i have owned a 2010 prius it was a good car reliable as hell front brakes at 120k new tires around 90 k lost it due to loosing my job. Now i have a 06 Jetta TDI pkg 2 dsg and she runs good but wasnt taken care of all the normal vw things like door harness etc need to be fixed and i wondering if i would be better off with a 2010 ? i am also about 3.5 hrs from you we go to columbia often and i wouldnt mind making some new friends ??
DanG144
Chapin, South Carolina, USA
2005 A4 Jetta 5spd
I do not feel qualified to pick between the '06 and the '10. I suspect that I would stay with the '06, but you would be welcome to come to the GTG and get plenty of input.
JesseP
Charleston, SC
'11 Golf TDI DSG
New to forum in Charleston
New to the forum, just bought an '11 Golf TDI DSG in January '14. Hoping to make it to the GTG from Charleston, SC.
Came across your thread from some other A/C troubleshooting threads, mine started acting funny a month or so ago and finally quit altogether. Any recommendations for shops in Charleston? Thanks for hosting, looking forward to this meet
DanG144
2005 A4 Jetta 5spd
Jessie,
Welcome.
I do not have any recommendations for a shop in Charleston.
If you are ever up this way, we could do the troubleshooting. Probably 9 times out of 10 it is a stuck RCV. If you would take a look at your RCV to see what type of mount it is, I could see if I have one here already.
In any case troubleshooting AC and replacing an RCV (if we have one) are perfectly reasonable jobs to do at the GTG.
DanG144
2005 A4 Jetta 5spd
I am in the process of updating the Tuners and Mechanics that plan to attend.
Putting that info in the first post.
If I miss any mechanics or product vendors that are showing up, please just contact me.
Also, if I have not sent you my address and phone number, let me know.
Dan
TDI_Brad
SC
Passat TDI SEL
Dan do you know if Andrew will be offering any discounts on tunes or parts? Or should shoot him that question? I have my VW Goodwill money and think a stage 2 tune and Less restrictive exhaust would be a good way to spend it. I had considered stage 3 and CR190 turbo swap but wasn't liking the $/HP ratio so stage 2 will have to do, for now.
Sent from my iPhone using TheChive - KCCO!
TDI_Brad
SC
Passat TDI SEL
I need to change my NOx sensor is that something that could happen at the GTG?
DanG144
2005 A4 Jetta 5spd
I would have to do my homework, but typically changing out an oxygen sensor on a MkIV would be reasonable.
Anybody know any details on this job - so I don't have to do homework?
TDI_Brad
SC
Passat TDI SEL
It's a 2012 Passat BTW. I assume that the NOx sensor still has to function properly with a stage 2 and less restrictive exhaust.
DanG144
2005 A4 Jetta 5spd
Brad, I don't even have a manual to check how hard that sensor is to get to, or to replace or repair.
Have you checked your private messages?
Can you tell me exactly what codes you have on your NOx sensor? I have never even seen a NOx sensor,
TDI_Brad
SC
Passat TDI SEL
Yes I check my messages last I got from you was your address.
As for the code I will check my VCDS log when I get home from work today. Heck I may even run another check and make sure no other codes have come up.
03PlatinumTDI
Mooresville, NC.
Diesel Free after 14 years
I'm going to join in the fun Dan. Haven't been down to see you in a while. You've helped me in the past with my timing belt change and an A/C compressor clutch change. Which I'm still in debt to you for.
The old Jetta is still piling on the miles. Looking forward to seeing everybody.
DanG144
2005 A4 Jetta 5spd
Brad,
If you want to wait, I have the word that the NOx sensor is a GTG level job. So count on doing it at the GTG.
I just wanted to ensure the instructions weren't "remove the engine and transmission, then cut the compartment open...".
TDI_Brad
SC
Passat TDI SEL
Brad,
Well I will run the code again when I get home. From what I've been reading the part #03L907807AD is what I will need. Some places have it listed as NOx sensor others say Oxygen sensor with control module but it all the same part number with prices ranging from $380 to $520.
TDI_Brad
SC
Passat TDI SEL
Dan here is the log from the scan. I have never posted one of these so I hope I have linked correctly.
PHP:
Wednesday,16,December,2015,17:11:45:63363
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
www.Ross-Tech.com
VIN: 1VWCN7A39CC019016   License Plate:
Mileage: 126420km-78553mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
 VIN: 1VWCN7A39CC019016   Mileage: 126420km-78553miles
 01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
   Part No SW: 03L 906 012 BP    HW: 03L 907 309 S
   Component: R4 2,0L EDC   H21 7445
   Revision: 71H21---    Serial number:
   Coding: 001D0012042400008000
   Shop #: WSC 57857 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906012BP 004009
   ROD: EV_ECM20TDI01103L906012BP.rod
   VCID: 73E56926DA42ABA666-8026
 2 Faults Found:
9688 - Reductant Tank Temperature Sensor
          P205B 00 [237] - Implausible Signal
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 116712 km
                    Date: 2015.08.21
                    Time: 04:13:12
 15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
 Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 054 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2806
   Revision: 05351113    Serial number: 00001105130587
   Coding: 0000020
   Shop #: WSC 09003 957 00200
   VCID: 162370B221701E8EA1-8042
 No fault code found.
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: C54BC0F549230003A30B03E5921F0042A70000
   VCID: 7BF54106FA12E3E63E-802E
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0149961923
   Coding: 130C0C
   ASAM Dataset: EV_KESSYPQ35G A02014
   ROD: EV_KESSYPQ35G.rod
   VCID: 3467AA3A9FCCEC9EBF-8060
 1 Fault Found:
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 123
                    Mileage: 124247 km
                    Date: 2015.11.20
                    Time: 01:38:43
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 561 907 044 D    HW: 561 907 044 D
   Component: Climatronic   H01 0102
   Revision: 00001001
   Coding: 0010001012
   ASAM Dataset: EV_ACClimaBHBVW411 A01001
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: 183F7E8AE36428FEB3-804C
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
   Component: BCM PQ35 H+   111 0148
   Revision: BL111001
   Coding: 6F200E3FF82B08D408880201360009E000F5008045A005F0E9846004BC70
   VCID: 4385F9E6C2625B2636-8016
    Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 100911 05  54  0403
   Coding: 06300A
 2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 30
                    Reset counter: 158
                    Mileage: 116697 km
                    Time Indication: 0
                    Date: 2015.08.20
                    Time: 14:56:46
              Freeze Frame:
                        Term 15 On
                    Voltage: 13.50 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
 02746 - Bulb for Daytime Running Light; Right
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 30
                    Reset counter: 158
                    Mileage: 116697 km
                    Time Indication: 0
                    Date: 2015.08.20
                    Time: 14:56:46
              Freeze Frame:
                        Term 15 On
                    Voltage: 13.50 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM003UT
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 6FED6556B66A8F4682-803A
    Seat occupied recognition:
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100007D7T0P
   Coding: 303252
    Crash sensor for side airbag; driver side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME6D481542ZZZ-
    Crash sensor for side airbag; front passenger side:
   Subsystem 3 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME68260362ZZZR
    Crash sensor for side airbag; rear; driver side:
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H02 ----
   Serial number: 3516KSME7C1A6C11ZZZ$
    Crash sensor for side airbag; rear; passenger side:
   Subsystem 5 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H02 ----
   Serial number: 3526KSME3D1B3513ZZZU
    Crash sensor for front airbag; driver side:
   Subsystem 6 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Fahr  H02 ----
   Serial number: 3556LSME0C573E0FZZZ7
    Crash sensor for front airbag; front passenger side:
   Subsystem 7 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Beif  H02 ----
   Serial number: 3566LSME415C3E0FZZZ6
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110710200404
   Coding: 001A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DF14F1EEC06EDD600-8028
    Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-YVJ  H06 0022
   Coding: E30000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Serial number: 00000000000000
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 1A3B64821D683AEE85-804E
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 11091101290992
   Coding: 461000
   VCID: 387F9E0A8BA408FE93-806C
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H07 0507
   Serial number:
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6ADB74428D886A6ED5-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000187751005
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E53B85271E0C64EC9-807A
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660712349
   Coding: 010000
   VCID: 29594B4E400EA1761C-807C
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000013696834
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 60CF166A73B4203E0B-8034
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3C8 035 684 E    HW: 3C0 035 684 E
   Component: RNS-MID       H59 3690
   Revision: AB001001    Serial number: VWZ6Z7L6212127
   Coding: 0409000201000094000B
   Shop #: WSC 07346 444 10517
   VCID: 2D51BF5E74E6BD56F0-8078
 1 Fault Found:
02635 - Tuner Not Enabled/Activated
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 7
                    Fault Frequency: 207
                    Reset counter: 117
                    Mileage: 116696 km
                    Time Indication: 0
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0525
   Revision: 12110009    Serial number: 0003260051
   Coding: 0405FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C37629A175C44DE97-8048
    Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Serial number: --------------------
   Coding: 800000
 1 Fault Found:
67584 - Warning Light for Front Door
          B11F5 01 [009] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 119
                    Reset counter: 118
                    Mileage: 116697 km
                    Date: 2015.08.20
                    Time: 14:56:14
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 290    3201
   Revision: 00H20000
   Shop #: WSC 01357 011 00200
   VCID: 3467AA3A57CCEC9EBF-8060
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225319882084
   ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 306FA62A6BD4D0BEDB-8064
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H40 1620
   Coding: 01020108
   VCID: 6FED6556BE6A8F4682-803A
    Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Coding: 181100
    Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0002
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0525
   Revision: 14110009    Serial number: 0002916333
   Coding: 0405FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D316F9E0C464DD660-8048
    Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
 1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 45
                    Reset counter: 99
                    Mileage: 116827 km
                    Date: 2015.08.21
                    Time: 18:34:36
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
 1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 7
                    Reset counter: 117
                    Mileage: 116696 km
                    Time Indication: 0
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660601552
   Coding: 0A10040000010110
   Shop #: WSC 07346 444 105175
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
   VCID: 3561973E94B6F59688-8060
 End-------------------------(Elapsed Time: 03:47)--------------------------
AARodriguez Corp.
TDIClub Enthusiast, Vendor , w/Business number
South East USA
2009 JSW and Golf 2004 TDI
Looking forward to coming out! We will be tuning of course and I will be able to program keys for MK4, MK6 and NMS Passat, please order the keys ahead of time, I don't think we will bring the key cutting machine.
GCBUG00
Hartsville SC
2000 Beetle
2000 Beetle. If anybody has a right rear tail light assy, I'm in the market.
You'll see the rest of the story.
Se ya in Chapin.
terrydtdi
Charleston S.C.
2000 MK4 TDI Jetta 5spd
Se ya in Chapin.
Gary, I'll keep an eye out at LKQ. I'll probably run out there sometime this week. Are they model year specific as far a style of the lens?
chapindad
Chapin, SC
I am very disappointed for two reasons. I will be leaving on that date for a week, and would have loved to come to this GTG. I do not have anything to be done, as I am new to the TDI. I have a 2015 Audi A3 TDI but I am a shade tree mechanic so I would love to come to the next one just to talk. Also, I have lived in Chapin for over 20+ years, grew up in Columbia, and have had one child that graduated Chapin HS and another that is a freshman playing football for Chapin HS.
I will watching out for the next one. Maybe in the spring when it is nice to be outside. It is getting cold....
GCBUG00
Hartsville SC
2000 Beetle
Terry, not 100% but 98-05 might fit. Not really worried about match, yet. Wait till you see the rest of the story. But it's still ticking.
Dan, I still have that fan module with your name on it.
GrndZero
NC-US
2015 GSW-SE6spd
This would be my first VW meet as I bought my new GSW back in August and am curious about attending. I went through the thread but I have yet to see an address, do you PM those to people? I will be coming from Fayetteville. Curious which way Jimbote will be taking and maybe I can drive down with him.
