T-b0ne
My buddy took the "geared" or toothed shift tab off the side and now that everything is back in the car will not shift past reverse. This is due to it getting jammed up on the gusset on the back of the trans directly behind it. I assume there is a certain position the shift selector should be in before it is put back on the gear but have no idea where to put it? The cable only reaches so far and then you have to use the slide piece between the cable and the geared tab. Anyone know of any way to figure out where either or both of these parts need to be for the car to shift correctly all the way to the bottom or "S" sport mode?
Any help you guys can give me or point me to in the forums would be appreciated I looked around but haven't found anything relative to this issue?
