Digital Corpus
Cliff notes:
Grinding noise is still present, but subdued. Similar to what I've heard with a delayed retraction of the starter's gear, but not the same. There was 10-20% of the OE level of gear oil present during the testing.
I never heard the car operate prior to pulling the transmission when the original problem occured. The driver is not savvy enough to note a slipping clutch until stopping at a read light and smelling the clutch. Driver tried repeatedly to get the transmission into gear and reverse with a broken/breaking shift linkage. Succeeded when the car was off and I assume slipped it and limped it home in 2nd.
Did I cause damage to the transmission, or was it caused by the driver. This is a car of our family and was driven by a family member so speculation does have any legal discourse, in case you're wondering.
- Pulled transmission for a burnt clutch due to a broken shift linkage
- Driver didn't know that they were slipping the clutch and limped the car home
- Sleep wasn't on my side
- Power washed transmission before reinstalling and noted that I did loose some trans fluid
- Forgot to check how much I lost by re-adding gear oil back in
- Started car and shut it off after about 10 seconds due to grinding noise that sounded like the starter not releasing
- Checked shift linkage alignment with wheels in air, idling, 1 thru 5 and watched speedometer climb
- Progressively diagnosed starter out of the picture with some engine idle run-time
- Looked inside trans's fill port
- *mental recital of expletives*
- Never revved the engine, between 0.1 and 0.2 miles "driven" (freewheeling in air)
- Filled with ~0.3-0.4 quarts or liters of G60 and topped off to overflowing with MTL
