Hi all,
Got problems with a newly acquired VW 2012 Jetta TDi 6-speed with "slipping" clutch when accelerating hard in 3rd or 4th gear. To me, sounded like a clutch issue.
Took them to Mister Transmission (yeah, I know...). They took it apart and the following damage appear on the transmission (see pictures). They're (obviously) telling me I need a new transmission for a whopping $1,500. Outside of the rub mark, the transmission is fine, no leaks or anything.
While I still think the clutch need replacement, I do not know however HOW the damage occurred to begin with
The clutch assembly is a rather expensive set with several parts (flywheel, friction plate, pressure plate). I'm trying to find out what actually needs to be replaced. Thought I would get an opinion of my trusted peers before authorizing anything.
Thoughts?
https://s9wyaa-ch3301.files.1drv.co...Y9YiKYunuw?width=800&height=600&cropmode=none
https://stw6aa-ch3301.files.1drv.co...V8XdXDVjg?width=768&height=1024&cropmode=none
https://stw5aa-ch3301.files.1drv.co...UVZtfAUXsw?width=600&height=800&cropmode=none
https://s9wxaa-ch3301.files.1drv.co...AETVcJgeeQ?width=600&height=800&cropmode=none
Thoughts?
