Chris_TDI_98
Replacing the rear wheel bearing on the 98 mk3 Jetta TDI.
The axle nut tightens most of the way, then spins in place, it won't tighten enough to expose enough of the hole to get the cotter pin through.
How do you get the cotter pin through, without causing permanent damage to the stub axle ?
