TonyJetta
- Joined
- Sep 15, 2005
- Location
- Tucson, Az
- TDI
- '15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
So...I read through all the threads about cleaning sunroof drains. Checked all 4 of them and found them all to be clear. I tried adjusting the sunroof, per Bently. I still had a leak. When I say leak, the entire perimeter of the headliner opening for the sunroof was wet. This was after <1minute of running water over the sunroof.
So, I ordered a new seal, thinking how bad can it be? Oh, it's bad. Blisters on both thumbs.
I'm pretty much committed to the new seal; I pulled off the old one and have made several attempts to install the new seal, but no luck. I get 2-3" and then it comes off. Going around a corner seems to be easiest to get started. The straight edges are what's killing me.
BTW...The front suspension is apart, going back together tomorrow, and we are enjoying pretty fair weather. Although I do have the roof covered with plastic, just in case.
Anyone have any tips?
Tony
Tony
