timmyd
1. what does it do?
2. What does it look like/where can I find it on the IP?
3. How can I test if its working?
I have a bit of a cold start problem in temperatures below -10C. I have already checked the usually suspects..
Replaced:
4 GPs (due to CEL)
GP harness (due to CEL)
coolent temp sensor (due to CEL)
..these helped a lot with getting decent starts up to -7C, use to be much worse.
fuel filter
injection timing set at 50-55
cleaned EGR valve
new fuel filter
diesel purge
OEM Battery
Replaced:
4 GPs (due to CEL)
fuel filter
cleaned EGR valve
new fuel filter
diesel purge
OEM Battery
