Old May 15th, 2017, 08:09   #16
kevkor2002
The dealer hooked me with the lightning cable version of the cable but I had asked for the usb version. No ones fault just a mix up on communication. I had asked for the lightning before I knew there was a USB version. Verbally asking for a different one didn't make it up the channels. I'd rather have the flexibility of the USB one but the lightning works just fine so I can't complain. The dealer did right by my request....I just requested the wrong one first
kevkor2002 is offline   Reply With Quote
Old May 15th, 2017, 08:11   #17
kevkor2002
Originally Posted by alex97jazzblue View Post
Obsessed with figuring this out. I am willing to buy a usb for $12 on ebay or for $26 you get the cables from china. I just can not believe no one has figured this out and VW does not have a bulletin out for the dealer to do the job and make some money.
https://www.aliexpress.com/item/Genu...4-82a5f8d53ac6
Mr Guinea pig...if this works I'll be buying next Good luck I hope its the right one for the job!!
Old May 15th, 2017, 09:14   #18
giuseppe_b
Fuel Economy: 42 mpg avg
I looked at those links and am a bit confused. What head unit do the MK7 GSW / Golfs have? It looked like we would have to buy a new unit as well as the wiring and new ports for the cubbie.
Or would that port/connector in the cubbie and a new wire + recoding work?
giuseppe_b is offline   Reply With Quote
Old May 19th, 2017, 09:41   #19
bigdaddylee82
TDI(s): '09 Jetta
We bought our '15 Golf TDI SE with "Fender audio" on the 31st of April.
We got the older 30 pin iDevice cable with our car, like everyone else. I still have an old iPhone for work that uses the 30 pin charger, so I thought I could still get some use out of it. However when I plug my iPhone into the cable, it shows up as an iPod with no media present, it's a work phone so I don't have any music saved to it, but it has unlimited data so I frequently use it for streaming services. I cannot stream Pandora, Slacker, or anything else over the cable, I just get told there's no media on the iPod.
That's frustrating, because on our '14 JSW I could plug my work iPhone into the cable, stream Slacker over the radio, and have my personal phone connected to Bluetooth for calls. On the '15 streaming only seems to work via Bluetooth, and I can't have more than one phone connected to Bluetooth at a time, so I'm left to choose between hands free calling on my personal phone, or streaming music from my work phone.
VW called with a survey about our purchase today, asked me a few questions, and then asked me if I had any questions. I asked if there was an updated MDI cable, they apologized for us having the wrong cable, but didn't provide any relevant information. Instead they are sending us a $300 Visa gift card for the our inconvenience. I didn't ask to be given a cable, or for any kind of compensation, they just offered to send a gift card to buy a new cable with.
2014 JSW TDI Candy White DSG Sunroof
2̶0̶0̶9̶ ̶J̶e̶t̶t̶a̶ ̶T̶D̶I̶ ̶R̶e̶f̶l̶e̶x̶ ̶S̶i̶l̶v̶e̶r̶ ̶D̶S̶G̶ ̶S̶u̶n̶r̶o̶o̶f̶ RIP
bigdaddylee82 is offline   Reply With Quote
Old May 20th, 2017, 07:06   #20
RunningSnail
TDI(s): 2015 Golf SE
Getting a little off topic, I find sometimes when connected via BT, the MEDIA button will stream music on my phone, other times Pandora. Neither app will be open. If I want to make sure Pandora plays, I have to open the app before selecting media.
Haven't tried with the cable.
RunningSnail is offline   Reply With Quote
Old May 20th, 2017, 07:39   #21
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
I get this occasionally as well. It will just start auto-playing Spotify unless I get Pandora open in a reasonable time. Can't find any settings in Spotify for auto-play either...
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
adjat84th is offline   Reply With Quote
Old May 21st, 2017, 10:42   #22
giuseppe_b
I happened to talk to the service manager at my dealer and asked him about this, he said that they sell a cable that will adapt to the old connection, as others have mentioned above.
However, I called VW customer care with a different question, and thought to ask her about this. After holding for several minutes, she told me that at this time they have no solution to the old school cable on newer phones. Just goes to show that one hand does not know what the other is doing.
On my 2010, it has the same old cable and I bought an adapter from Apple to use 40 pin to Lightning for my wife's iPhone. It does not work well at all, I hope VW's is better.
I have an android and have little hope of using a cable with the 2015 system unless someone can verify that it works.
Else I will try the vortex solution at some point.
Old May 22nd, 2017, 06:33   #23
alex97jazzblue
TDI(s): ALH, BRM
Im taking us back on topic here folks. The point of this thread is to determine how we transfer the mmi connector in the ashtray of the 2015- models to the USB version found on 2016+ models.
I will be the guinea pig and order the chinese part from Ebay and then determine however I am little unsure if this would work simply because China calls it "car play" which is not what the 2015 models have.
Here is a link. Thoughts?
http://www.ebay.com/itm/AUX-in-USB-C...oAAOSwKytZHAN3
1990 Corrada 1z
2002 Jetta ALH Vnt17
1981 Rabbit Pickup 1.6TD
1997 GTI VR6 Gt35
alex97jazzblue is offline   Reply With Quote
Old May 22nd, 2017, 07:30   #24
kjclow
Originally Posted by KnightWolf View Post
My sales guy got me one when I picked up my golf, but doesn't seem to work. Shows connecting on the screen for about 2-3 seconds, starts to charge the battery, then nothing. Am I missing something? Haven't had time to go back, maybe this weekend I'll speak with them.
If you have a case on your phone, it may not be making a complete connection. My wife has a car charger that will work without her taking off the phone case but not mine.
Old May 22nd, 2017, 08:32   #25
capt_slow
capt_slow's Avatar
I bought one of these for my older TDI just as Apple introduced the Lightning connector. Works for data and power in both of my TDIs.
http://a.co/aDq8WD3
2010 Jetta TDI: Reflex Silver, DSG, Moonroof
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, Driver Assist Pkg, M-Sport Pkg, Premium Pkg, ACC, Side/Top Cameras, Park Assist, Nav, HK
2015 GSW TDI SEL: Pure White, DSG
capt_slow is offline   Reply With Quote
Old May 22nd, 2017, 10:26   #26
krebsy75
This is the solution I've been rolling with for years. The "Lightening" version of the MDI cable isn't compatible with most phone cases. It's close to useless.
http://a.co/aDq8WD3
krebsy75 is online now   Reply With Quote
Old May 26th, 2017, 21:58   #27
aditud
http://a.co/aDq8WD3
This. I have it and works great. Streams music from iPhone w/out activating bluetooth.
aditud is offline   Reply With Quote
Old May 27th, 2017, 08:03   #28
vikingtdi
TDI(s): '11 JSW
I've been so close to pulling trigger myself on that! Hope you're able to guinea pig that but I might end up doing so as well. It's much cleaner than several cables IMO. Please let us know how it goes.
vikingtdi is offline   Reply With Quote
Old May 30th, 2017, 05:38   #29
alex97jazzblue
TDI(s): ALH, BRM
I have not yet ordered because i bought a new '15 for work and 2 weeks later they tell me they are giving me a focus instead of reimbursement!
WE NEED TO DETERMINE is that part will allow one to at least charge a android based phone that requires the fast charging. IF the data does not connect I am not making a fuss since the car has blue tooth. I personally am trying to eliminate the use for car charger by utilizing a retractable android usb cable.
1990 Corrada 1z
1997 GTI VR6 Gt35
Old May 30th, 2017, 06:33   #30
Grigg3
Several folks say this works... but
http://a.co/aDq8WD3
I have that apple 30 pin to lightning adapter and the MDI to 30 pin cable that came in the 2015 GSW.
This combination does not charge my ipod, and is slow to update song info on the screen after forwarding to the next song.
I ordered VW cable 5N0-035-554-H which is the MDI to lightning and it works great, quicker to update info on the screen and it charges the ipod.
Mistakenly I was sent 5N0-035-554-G and it did not work at all, would not connect or charge.
There are a few other part numbers for various lightning adapters from VW, so don't get confused and buy any random adapter.
The 5N0-035-554-H is what works in the 2015 GSW in my experience and from my research. Nowhere did I find a clear accurate list of what cables work with which model cars, it's a mess.
Otherwise the whole idea to swap the MDI socket out for USB/aux is very interesting, I hope someone figures out what's involved.
05 Jetta wagon, 15 Golf wagon
Grigg3 is offline   Reply With Quote
FS: OEM VW Ipod (30-pin) Media Cable 5N0035554B - $50.00 Bassive1 Private TDI Items for Sale/Wanted 1 May 16th, 2015 14:47
WTB: Media Device Interface kit flyguy38 Private TDI Items for Sale/Wanted 0 June 27th, 2011 13:32
Do Ipod AND USB media interface cables come with the 2011's? c17chief VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 September 24th, 2010 05:57
problems with vag cable interface silverbeast OBD Scanners 4 July 22nd, 2005 10:25
Wanted: VAGCOM interface cable Fast Private TDI Items for Sale/Wanted 0 January 22nd, 2005 16:41
Page generated in 0.17972 seconds with 13 queries
[Output: 132.19 Kb. compressed to 111.38 Kb. by saving 20.81 Kb. (15.74%)]
