Old May 18th, 2017, 12:24   #91
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Measured on 2 different dyno. Injectors not even the owner knows who makes them, we have tried to trace the package haha ..imagine that, to see where it came from.
Im sure if Ruben makes huge power he wont say anything about important HW parts.
Just the way things are.
Will see soon how it goes on 402m.
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old May 18th, 2017, 13:13   #92
Rub87
30% losses.. as in over 100hp, sounds a lot.
What you guys need to realize is that major part of losses are an additive component, and only a small part are factor componenent.
Example
100 engine hp car driving 250 kph on rollers (4wd 2 rolls per wheel) has lets say 65 whp. Making for 35 hp or 35% loss at 250 kph. Lets say 30 hp is loss of tyres at the wheels, and 5 hp is loss in gearbox/diff etc.
500 engine hp car driving 250 kph on same dyno and 450 at the wheels. Due to the slightly larger slip of tyre, the tyre loss might now be 35-40 hp, and geabox loss lets say 10-15 hp. Making the total loss only about 10-15% max
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old May 18th, 2017, 17:56   #93
raffshore
I am sure now kids beat you up at school
raffshore is offline   Reply With Quote
Old May 19th, 2017, 00:37   #94
Turbo Z
if you say that about Ruben you are heavily mistaken...
Turbo Z is offline   Reply With Quote
Old May 19th, 2017, 07:57   #95
Macradiators.com
Couldnt be more wrong about that
only 15% loss on quattro? wow
maybe on a FWD
CP3 Upgrade
Old May 19th, 2017, 11:28   #96
hatemi
Last quattro I dynoed had 295whp and 337 calculated at the crank. A6 3.0TDI Tip.
Measured in fourth gear. Losses go up if speed is higher.
The dyno had large 600mm diameter rolls. With smaler rollers and cradle rolls ( ie dynamics, mainline, bosch lps,) losses are usually tad higher.
Lähetetty minun Moto G (4) laitteesta Tapatalkilla
www.tdituning.fi
hatemi is offline   Reply With Quote
Old May 19th, 2017, 12:02   #97
Rub87
jep. type of roll makes biggest impact on losses. and you cannot say this losses in % of engine HP. if you double engine HP these losses will be nearly constant if you drive same speed on the dyno
Old May 19th, 2017, 12:54   #98
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
I find that the small roller dynos are more accurate than the large roller ones.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old May 19th, 2017, 13:04   #99
xjay1337
Using a dyno to measure before and after is fine but without strapping lots of cars down at the same day on the same dyno it's hard to measure with certainty or accuracy especially as it seems some peoples figures are crazy. Or you can gain free bhp by adding "w" before the "hp"
I prefer 1/4 mile times (mainly terminal speeds) as an indicator of performance as it's generally harder to fudge the figures and provides greater indication of real world performance.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 340hp 625nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3” Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old May 19th, 2017, 15:02   #100
sam-
I personnally look more a 100-200km/h times (especially when done with 5hz or higher gps rate) as on a 1/4 some cars suffer of traction problem.
sam- is online now   Reply With Quote
Old May 19th, 2017, 15:07   #101
Rub87
Opposite. The bigger roll the less loss at tyre.
On dyno with 2 8' rolls per wheel a 4wd 100 hp car has like 0 wp at 270 kph. Doesnt sound good no?
Old May 19th, 2017, 16:59   #102
mrchill
mrchill's Avatar
Interesting. Because we have tested it over and over...and gotten confirmation from the dyno manufacturers that the small rollers with less inertia are more accurate than the large one...also, they (small rollers)are more sensitive to changes(when diagnosing driveability). One thing we do besides always using the same dyno when charting changes, is to run a couple of stock, unmodified cars first, in order to get a sense of the dyno and the operator....as these are also factors in addition to the settings.
Old May 19th, 2017, 22:44   #103
hatemi
Keeping in line worh the OT talk here😀
The most common dyno in US is Dynojet. Its usually regarded as the standard and what others are compared to. It is also regarded as the most optimistic of them all. As a matter a fact some other brands have "dynojet correction factor" to be able to make them read similar values as the dynojets in the area and to satisfy the fat corvette drivers etc.
Almost all of them have some way the operator can affect the readings. Dynamics with the shootout mode is a good way of keeping the operator out of the results.
Small roller vs big roller and inertia vs braked is another common battle. Both methods have their pros and cons. Inertia is accurate and simple way of measuring the power. You cant tune steady state or part load areas with just inertia so for tuning stand alone ecus they are far from optimal. This is where small roller low inertia braked dynos realy shine. You can select a rpm or speed and the dyno keeps the engine at that point no matter if the go fast pedal is at 10% or 100%.
www.tdituning.fi
Old May 20th, 2017, 02:09   #104
Macradiators.com
Playing with parameters on the latest Soft Engine dyno ..only gained 3hp. Cant mess with it, a 390hp rated car tuned elswhere , gave only 347 on this one.
It just re calibrates and throws out the same result if you mess with it.
I guess this tuner wont be making world record numbers on it.
CP3 Upgrade
Old May 20th, 2017, 02:53   #105
Rub87
Yes, very intereststing is that the only type of roll allowed to do emission certification for example is a big single roll/wheel with 48' diameter. must be pure coincidence
World Record MPG TDI For Sale Beeah TDI Cars for Sale/Wanted 0 April 14th, 2010 01:13
New Guinness mileage Record TDI/Goodyear fgbrault VW MKV-A5 Golf/Jettas 9 August 21st, 2009 20:59
TDI speed record Jester General VW Discussion 2 April 28th, 2009 14:15
TDI Reliability Reputation/Record Rickdude TDI 101 30 September 11th, 2005 20:14
TDI Land Speed Record suffeks VW MKIV-A4 TDIs (VE and PD) 35 January 20th, 2004 14:21
Page generated in 0.19196 seconds with 13 queries
[Output: 133.51 Kb. compressed to 112.18 Kb. by saving 21.33 Kb. (15.98%)]
