Old November 19th, 2016, 16:09   #61
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
You know now that you brought that up,I never thought about filling it.
Kind of too late now...will have go slow when fueling up.
The baffle closest to the filler neck has some good gaps so that's not a problem.
I can reach my hand through the sending unit hole with the plasma,I will cut
two 1 1/2" holes in the other baffle.
1.9ZOOK is offline   Reply With Quote
Old November 24th, 2016, 19:41   #62
andy2
andy2's Avatar
Nice work with the fuel tank mod! I modded my fuel cell pickup to pull fuel from the rear end of the fuel cell so that there would be no issues.I also keep my fuel cell full to avoid problems.I've yet to starve for fuel when running my buggy on its side or attempting to climb a steep grade.
andy2 is offline   Reply With Quote
Old December 16th, 2016, 19:45   #63
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Thanx Andy,
yeah I would run out on obstacles like this when really laid over.
I don't plan on doing this with the diesel,more of a really capable camping
rig.
So way back when I was making the full circle adapter plate I made this statement
"How often does anyone take the oil pan off anyway" apparently when the diff makes
a hole in it.I had extreme death wobble because I forgot to swap out the blown steering
stabilizer(since replaced,no more bump steer)
So I cut out the hole and clearanced it.
...and rebuild the tranny,had over 200K on it and the added torque was to much for the worn bearings.
some tranny photos for entertainment only.
Wasn't as hard as I thought removing the tranny,in fact is easier than my `88 Toyota truck.
I was pleased to find no strange wear of any sort,pilot bushing,pressure plate,clutch all looked
good, so brought some piece of mind.
I have coated the fuel tank and it has dried for 3 days,goes back in tomorrow then test drive
again.
Old March 21st, 2017, 18:54   #64
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Under the knife again...
I wanted the selectable locker cause the auto locker was way to squirrely in sloppy snow
conditions.
It was time to fab up the E-locker in the front axle,
Fortunately the locker came with the center housing making this chore easier.
Started by cutting out part of the face where the motor sticks out.
I had already modded the U-bolt and perch with welded in studs cause I knew the motor would be all over it.
Welded in the e-locker housing piece.
Had to trim a fraction of the modded perch
Pretty close but makes it.
Ready for some silicone and reassembly.
Added a gusset between the welded studs for a little extra support.
I also re-geared the rear to mach the front (4:10) At 25mph and 31" tires,2nd was over revving and 3rd was lugging,so now I can stay in 2nd.
Old March 23rd, 2017, 17:51   #65
Motohead1
Nice work Zook. Do you know how much your rig weighs?
Motohead1 is offline   Reply With Quote
Old March 23rd, 2017, 18:16   #66
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Thanks Moto
Haven't weighed it yet but I'm guessing around 3100.
Old March 24th, 2017, 17:52   #67
smelly621
Didn't realize your build thread had so much good swap and fab porn! Nice work on the swap and the rig all around!
smelly621 is offline   Reply With Quote
Old March 24th, 2017, 20:11   #68
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Thanx smelly621
Few more photos on the front locker...
Made a shaft to use with broken motor body so it can be manual.
Then made a lever to actuate it.
I have an old Samurai clutch cable and a 1/4" heim joint that will operate the locker,still have to figure out the handle.
Old May 18th, 2017, 19:00   #69
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
A little update,after 500ish miles it started to get a little clutch chatter and a
slight bearing noise.I knew the alignment was probably out since I never indicated it.
So made a tool out of an old w56 tranny nose piece.
It was off .018 up and down and .008 side to side.
I made some offset dowels and it just wasn't happening,so I took the dowels out
,indicated with all the bolts snugged,got it within 1.5 thou.Tightened all bolts
and rechecked,nothing moved then drilled and pined in place.
Pretty happy now...
I'll get it back together this weekend and test.
Also received my VCDS yesterday so that will be interesting.
Old June 8th, 2017, 14:52   #70
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
No more clutch shudder and everything is running smooth now.
Still haven't dug into the wiring yet but got some more fab work done.
Made some shift knobs and got the locker shifters and cables working,they
are effortless to lock and un-lock,so am happy about all that.
Photos of the lockers,still have to make rock guards for them.
And here's a video just for the heck of it...
https://www.youtube.com/watch?v=CEhh4DK6pPk
Thanx for lookin' Guys...
Old June 8th, 2017, 20:16   #71
Motohead1
Nice looks like fun.
Old June 12th, 2017, 21:38   #72
smelly621
Looks super fun, and your manual locker conversion looks very nicely done as well. Jealous of your fabrication skills.
Those trails look fun - can you drop me a pm of where abouts you were? Would like to check them out next time I'm up your way.
Old August 15th, 2017, 19:37   #73
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Thanx Smelly621
Not much of an update,I've mainly been taking it out on short camping trips
close to home.I need to tune it up and find someone around here that can do
a timing belt change,but other than that it is like a pack mule on the trails towing
a trailer with four people in it.
Couple of photos with trailer...
Upper Lake Trail
Eddy Trail
Some day I will take on the challenge of re-posting the photos...
Old August 16th, 2017, 01:07   #74
jimbote
jimbote's Avatar
very cool man, are you near tahoe ? yeah reposting blocked b****t photos is almost as challenging as the builds themselves
jimbote is online now   Reply With Quote
Old August 16th, 2017, 07:23   #75
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Thanx Jim
I'm near Mt.Shasta about 250 miles north of Tahoe.
Samurai TDI swap Bczuk TDI Conversions 109 October 28th, 2015 21:03
Suzuki Samurai tdi50mpgnoob TDI Conversions 14 January 23rd, 2015 16:58
not so average tdi in samurai!! Kraiger TDI Conversions 61 August 1st, 2012 21:54
Diesel Suzuki Samurai GA_ZUK Private TDI Items for Sale/Wanted 8 March 7th, 2009 12:18
Suzuki Samurai gidb36 TDI Conversions 4 December 8th, 2005 14:40
Page generated in 0.16421 seconds with 13 queries
[Output: 129.91 Kb. compressed to 108.80 Kb. by saving 21.11 Kb. (16.25%)]
