cbauersr4
Intermittent \"misfire\" and flashing glow plug lamp
I have a '98 NB 5spd with about 122,000 miles. Starting a couple days ago just before I got to work(50 mile drive) the glow plug lamp flashed once with no abnormal engine response. That afternoon I was at highway cruise and the engine totally cut out for one revolution. Since then it has cutout several different times. I am not sure if the glow plug light flashes every time it cutouts but I have seen it happen a couple of different times. I have also had intermittent no starts since then; mostly after sitting in the hot afternoon sun. When this happens the check engine light and glow plug lights flash. I turn the key off and back on and everything is fine. I am thinking about relay 109? Am I on the right track? If so does anyone have a good description on where it is on my car?
