Old September 20th, 2018, 13:51   #1
castalncsc
TDI(s): 2008 jetta
Default Repair cost question... Starter
1. How much should a Starter replacement cost at the dealership?
My car would not turn over after stopping to run into the post office... so I had to have it towed to the local VW dealer. It is now fixed & I will pick it up tomorrow- and they are saying the price is $1150. (Does this seem high?)
Just the diagnostic charge was around $350 (a little over 2 hours @ $160/hour)... Should it take over 2 hours to diagnose a bad starter... on a car that won't start??
2. Separate Question (in case anyone happens to also know the answer)- How does a bad starter cause/ relate to ... not being able to read any codes (the code machine would not communicate- no codes came up)?
castalncsc is offline   Reply With Quote
Old September 23rd, 2018, 06:29   #2
JETaah
Fuel Economy: 53 max, 42 min, average 46
You probably paid the tech through his lunch hour
Have you ever had to crank the engine a lot to start it? I'm thinking corroded connections, burned solenoid contact or worn out motor brushes if it was actually a bad starter.
A bad engine ground or power connection may the cause starting issues. I have solved a couple of issues like that by cleaning the starter connections. I don't expect that the VW dealer would take that approach. It is all about the bottom line for them.
A faulty starter alone would not cause a fault code. A faulty engine/ECU ground might.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is online now   Reply With Quote
Old September 23rd, 2018, 18:03   #3
narongc73
A starter is a 20min job on these cars. Just diy it. Save yourself 900 bucks.
narongc73 is offline   Reply With Quote
Old September 24th, 2018, 01:58   #4
GoFaster
Moderator at Large
Original poster below their username says they have a "2008 Jetta" and are in the USA. If that's correct, it isn't a TDI. If the car in fact is a TDI, their signature is wrong.
This might not be a TDI that we are talking about here.
And, a starter motor that does not operate indeed does not trip any fault codes. It's a "dumb" hard-wired circuit - no on-board diagnostics are involved.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old September 24th, 2018, 03:43   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yeah I love how people ask a question, and provide no context.
A starter on a V8 Phaeton is a HUGE job. 14.2 hours labor, about $700 list price for the part.
A starter on a Jetta could be all over the place, as there have been about 15 different engines bolted to about 8 different transmissions in cars bearing the "Jetta" badge over the years.
So do we get to guess?
oilhammer
www.cardocautomotive.com
Starter rebuld cost? annieneff VW MKIII-A3/B4 TDIs 9 May 23rd, 2015 13:53
a/c repair cost UnReconstructed VW MKIII-A3/B4 TDIs 6 June 22nd, 2010 07:05
How much should this repair cost? MAPatronik TDI 101 6 November 25th, 2008 19:53
Engine repair cost? bullitt94 TDI 101 12 June 5th, 2008 15:53
dealership repair cost question jahfakin VW MKIV-A4 TDIs (VE and PD) 9 November 11th, 2004 20:41
Page generated in 0.17074 seconds with 11 queries
[Output: 69.63 Kb. compressed to 61.56 Kb. by saving 8.07 Kb. (11.59%)]
