Old September 11th, 2018, 18:45   #1
guinness1976
Default 06 deceleration turning sound
06 dsg 210,000 miles. I am getting a rubbing sound from the front right. Kind of like the wheel bearing. The weird thing is it only happens above 60mph, while turning right when i take my foot off the gas. Very consistent. Any ideas?
guinness1976 is offline   Reply With Quote
Old September 11th, 2018, 19:01   #2
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
Noises that become noticeable in turns are most common in both CV joints and wheel bearings. Lift the car's starboard bow and see if there is ANY play vertically or horizontally in the wheel. Front wheel bearing failure is apparently common. If there is no play, then it is probably the CV joint.
sptsailing is online now   Reply With Quote
Old September 11th, 2018, 19:20   #3
guinness1976
Thanks sptsailing. I am leaning towards the axle. It just started this evening, and havent had a chance to get under the car yet. The instantaneous on off linked to whether i am on the gas or off makes me think axle.
Old September 11th, 2018, 20:37   #4
sptsailing
sptsailing's Avatar
Take the axle off, as it it easy. You can tell then quickly if the wheel bearing is bad or not. Mine went bad at or before 146,000 miles. Very bad, dreadfully bad.
Humming sound when turning right JaY_III VW MKIV-A4 TDIs (VE and PD) 9 June 4th, 2013 18:39
clicking sound when turning V-Rod VW MKV-A5 Golf/Jettas 1 December 10th, 2012 15:48
Knock sound when turning Mikey2 VW B5 Passat TDIs 5 November 3rd, 2010 23:13
Clunking sound when turning verbalnoncents TDI 101 7 May 13th, 2009 07:44
strange sound when turning Hexar VW MKIII-A3/B4 TDIs 2 November 5th, 2007 23:16
Page generated in 0.12413 seconds with 11 queries
[Output: 62.16 Kb. compressed to 55.70 Kb. by saving 6.46 Kb. (10.40%)]
