Old September 11th, 2018, 11:26   #1
Überläufer
TDI(s): 2006 Jetta
Default Rear Wheel Bearing Axle Bolt Removal
Changing a rear wheel bearing on my MkV Jetta, I'm curious if it would be beneficial to have the axle bolt loosened 90 degrees while the tire is still on the ground, like the procedure for removing the axle bolt when changing the front bearings. With the rear hub I'm aware you have to remove the tire to get the dust cap off, but you could do that and then put the tire back on afterward to loosen the bolt. This made removing the axle bolt on the front a heck of a lot easier.
The torque spec on these bolts is 133 ft lb, then a 1/4 turn, so almost as much as the bolt on the front wheels. Reading up on removing the rear before the part comes in, it looks like it's just as much of a pain to remove as the front, almost. Does this sound practical, or is there any reason I should avoid moving the bolt while the wheel is still on the ground? Thanks.
Überläufer is offline   Reply With Quote
Old September 11th, 2018, 18:06   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Makes no odds, on the front you're stopping the wheel from spinning because the bolt goes into the driveshaft but the bolt on the rear goes into a solid mounting so wheel on the ground makes no difference.
Seatman is offline   Reply With Quote
FS: Snap On Wheel Bearing Installer Tool 3420 For A4 Rear Wheel Bearing TdiTaff Private TDI Items for Sale/Wanted 0 August 15th, 2016 20:29
Rear Wheel bearing shoulder bolt torque jmarshall VW MKVI-A6 Jetta Sedan (~ 2011+) 4 June 6th, 2015 11:35
MkV Rear Wheel Bearing Axle Bolt (jetta 2005 & 2006) Please help! Parsimony23 TDI 101 2 December 27th, 2012 14:07
Wheel Bearing Bolt Torque MakingBoost VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 November 9th, 2011 14:51
rear wheel bearing removal sycofiend71 VW MKV-A5 Golf/Jettas 4 February 24th, 2011 11:30
Page generated in 0.14001 seconds with 11 queries
[Output: 52.24 Kb. compressed to 48.28 Kb. by saving 3.96 Kb. (7.58%)]
