Hi can't get my 2006 Jetta started after a camshaft replacement. Well it did run briefly on the first turnover then died. I cranked it over a couple more times nothing then a oil pressure warning light came on so I stopped. I followed the procedure carefully.
Only thing I can think of is I used Joe Gibbs BR40 which is a 10W-40 a little to viscous possibly tripping to the oil warning preventing starting?
I used the correct timing tools turned it over by hand twice no problem. I removed the tandem pump but left the fuel lines attached. VCDS shows nothing. I did have to tap in 3 of the oil galley plugs (one was missing) on the rocker arms they were working themselves out. I made a new plugfor the missing one closest to the tandem pump.
