farfrumsanity
Has anyone removed the wiper blades, if so how do they come off. I also saw that Bosch offers replacement wiper blade set for a 2005 Jetta, but does not specify if it is the MK-5. Eventually they will need replaced, and I would like to be able to purchase them from the aftermarket, not the dealer, as I usually run the Anco winter blades. Also Wix has oil filters available for the 2005-5 Jetta under part number 57083, and will soon have air filters under part number 49186, if the air filter is the same as the Gasser. The MK-4 air filters were the same, Diesel and Gas.
