mad_despot said:
> It would appear your car has a loose nut between the steering wheel and the drivers seat.
Well, I can't deny that!
Still want to know if the cooling fan ever actually gets used, I think I'm just going to have to experiment by disconnecting it and keeping an eye on the guage in traffic.
My car's cooling fans have turned on. Its been on hot summer days, 95+'F, stuck in a backup on the highway do to road work being done.
The OEM gauge is filtered to read 190' from about 170' to about 210'. So it isn't much better then a light. I take my Scangauge as being correct. When I see it go over 205' I have turned on the AC to have the fans run, and temp. comes back down.
From the Bentley manual for my 2004 Golf there is a
dual temperature SENSOR ( two sensors ) near the cylinder head, current design is with green plastic, for the ECU and dash. There is also a
dual temperature SWITCH ( two switches, each at a different temperature trip point ) in the radiator near the outlet hose going to the thermostat, (
cooled coolant )
for controlling the fans, low and high speed.
The
first SWITCH goes on at 92-97'C ( 197.6-206.6'F ) and back off at 84-91'C ( 183.2-195.8'F ) for low speed fan, the
second SWITCH goes on at 99-105'C ( 210.2-221'F ) and back off at 91-98'C ( 195.8-208.4'F ) for the high speed fan setting. The relay control module also cycles the fans on low speed with the AC.
So if the fan(s) don't go on when the temperature switch is at 221'F there is a problem. Hope this is of some help.
I do not like things running that hot
at the radiator outlet, as hoses and other items do not live as long at these temps.
