Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old May 26th, 2015, 14:53   #1
imo000
imo000's Avatar
Fuel Economy: Good enough
Default Passat B5.5 camshaft kit in Canada
With the USD so far apart from the CDN, I'm trying to buy/source a quality camshaft kit for my '05 Passat (BHW) engine for under $580 USD (on IDparts). Any recommendation is appreciated
imo000 is offline   Reply With Quote
Old May 26th, 2015, 15:24   #2
otty
otty's Avatar
Boraparts a LITTLE cheaper... maybe not after shipping:
http://shopping.boraparts.com/produc...roducts_id=480
Malone tuned stage 1 and loving it!
otty is offline   Reply With Quote
Old May 26th, 2015, 15:39   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Check with Perjad at precision, Brian at Roseland.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old May 27th, 2015, 06:53   #4
Johhny04
Also see what Jason at German OEM can do for you.
2003 Jetta TDi skid plate, GLI suspension, VR6 brakes, Fat 5 TT rims
2002 Ford E350 7.3L Powerstroke. Weekend workhorse that pulls like a freight train!....sold
2004 Jetta TDI ..... sold
Johhny04 is offline   Reply With Quote
Old May 27th, 2015, 08:14   #5
steve6
Brian at Roseland can get a lot of parts that are not listed, worth the call
steve6 is offline   Reply With Quote
Old May 27th, 2015, 14:07   #6
imo000
imo000's Avatar
Thanks for all the suggestions.
Old May 27th, 2015, 16:06   #7
Windex
Windex's Avatar
Update the thread on how you make out. Mine is fine for the moment, but I would like to have one on the shelf for when it does finally tank.
Old May 28th, 2015, 08:36   #8
imo000
imo000's Avatar
Will do. The #1 exhaust lobe is worn down by about 4mm. The rest of the exhaust lobes show slight wear. The car ran fine unitl the follower/hydraulic lifter top wore through and the exhaust cam stopped oppening. I limped home by meeping the rpms as low as between shifts and going 100km/h on the highway (figured the constant speed on the highway would cause the least amount of additional wear). It worked for me BUT when I took it apart, the check valve in the failed follower was close to popping out. So I don't recomend to drive it if you start running on 3 cylinders. I took a gamble and got lucky. Next time (if the '06 Jetta develops this), it will be towed home. If the follower top didn't wear through, I would have not known the lobe was that worn. The engine ran fine.
Old May 28th, 2015, 18:37   #9
dieselsipper
imo000:
you sticking with original grind or are you looking at stage 2?
dieselsipper is offline   Reply With Quote
Old May 29th, 2015, 09:33   #10
imo000
imo000's Avatar
Original spec.
Old June 2nd, 2015, 03:43   #11
imo000
imo000's Avatar
New camshaft kit is in the engine. Fired it up last night. Went with the AMC kit. Thanks QuickTD and Windex for your help. With some luck the front end will be bolted back up tomorrow evening, change the oil and then shakedown test drive to work on Friday......aftrr that heading to Montreal for the F1. I'll post pictures a little later.
Old June 2nd, 2015, 14:42   #12
otty
otty's Avatar
Where did you buy the AMC kit? How much all in?
Old June 4th, 2015, 07:51   #13
imo000
imo000's Avatar
I've got it through a buddy that had access to a wholesale account. He is not in the bussiness of doing this often therefore, I rather not disclose anything further than it was cheaper than buying the same kit through IDparts (including shipping and other costs).
Buttoned up the front end last night and went for a 20 minute shakedown test around the house. All looked well so took it to work today (160km round trip) as a bigger shakedown test. If all is well, tonight heading to Montreal for the F1.
As a note: The engine is noticably quiete (even before the taletail bad cam noise started), a lot smoother at idle and during driving and has more power off the line (don't have to work the clutch as much). Knowing what I know now, there were signs of the cam slowly wearing off I just didn't know and thought it was either the motor mounts and/or the clutch acting up. The #1 cylinder was slowly making less and less power as the exhaust lobe was wearing off to a stub.
I've also put a new timing belt on it since it was 20K km away from it's interval.
FS Canada/Sask - B5 Passat euro HID lights santacll Private TDI Items for Sale/Wanted 0 October 8th, 2014 15:49
FS: Passat B5.5 Votex ground effects kit vwztips Private TDI Items for Sale/Wanted 9 August 7th, 2011 08:11
searching coilovers kit for my passat 2005 b5.5 mousaillon VW B5 Passat TDIs 3 January 15th, 2010 14:04
Looking for projectors B5.5 passat in canada scottp Upgrades (non TDI Engine related) 0 July 25th, 2008 11:50
Viper Kit for the Passat B5 nApkIn TDI Power Enhancements 0 November 24th, 2001 00:23
Page generated in 0.16273 seconds with 11 queries
[Output: 112.19 Kb. compressed to 93.64 Kb. by saving 18.56 Kb. (16.54%)]
