Old November 3rd, 2012, 09:34   #1
RichA
Question Help with poor cold startup
This thread is in reference to my 2004 MKIV BEW Jetta. When the temps get cooler it becomes more and more difficult to start and keep running. The glow plugs were changed to the new ones under the recall. The ECM was re-mapped at the time of the recall. When it is cool to cold out and you attempt to start it, the car will either start and cut out immediately or start and run at a very low idle (400-500) and preform what I call lobing. Now the car has 205K and the cam was replaced at approx. 200K. Has anyone else experienced this problem or have an idea as to what might be causing it? Any ideas would be appreciated.
RichA is offline   Reply With Quote
Old November 4th, 2012, 07:05   #2
RichA
Bump. Anybody?
Old November 4th, 2012, 07:19   #3
Dieselducky
Dieselducky's Avatar
How long are you holding the starting on for?
Dieselducky is offline   Reply With Quote
Old November 4th, 2012, 08:33   #4
RichA
Until the glow plug indicator goes off. I make that this is done at every startup regardless of outside temperature.
Poor fueling when cold? Cold-blooded? theflyingturtle TDI 101 3 August 7th, 2011 11:31
No boost at cold startup dirtdub TDI 101 15 November 15th, 2008 07:11
cold startup problem on cold weather xls TDI 101 4 February 19th, 2008 08:31
Cold Engine Startup jap TDI 101 16 December 9th, 2003 14:39
Page generated in 0.11264 seconds with 11 queries
[Output: 62.77 Kb. compressed to 56.15 Kb. by saving 6.62 Kb. (10.55%)]
