Old December 5th, 2016, 06:55   #166
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Originally Posted by Bobt250 View Post
I bought a complete head and a turbo from him 5 years ago. 90k later and still running strong. I need another one for a different car and plan on buying from him again.
lol....have you looked at the cam? bet there isn't much left.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old December 5th, 2016, 07:01   #167
BuzzKen
BuzzKen's Avatar
I apologize for what appears to be a shill. The reason I was looking around is that I am in need of another head and was wondering what the word on him was now 5 years later. That's all, I'm not a shill, just stating my experience with him. I was planning on going straight to him (if I could find him) for another one but you guys have me concerned.
If I was a shill I would have been defending him years ago.
I only bought the head and turbo from him. I bought a timing belt kit from someone else that had a Conti belt. I've had good luck with those belts.
Can anyone say if they had a problem specifically with a head from this guy?
I seriously want to know because I need a head for an ALH
Just buy what you need from IDparts and you will be good.
Buzzken Exhaust
www.buzzken.com
tdiexhaust@hotmail.ca
BuzzKen is offline   Reply With Quote
Old December 5th, 2016, 07:04   #168
jasonTDI
jasonTDI's Avatar
Removed three of them over the last 7-8 years. One was so warped it puked the head gasket after 5k. Good thing as his "timing belt" was half its original width and would have caused far greater damage. The secong just ran very poorly after 20K. Lots of unburnt fuel smoke and very hard to start. The valve seats were so soft they pretty much either eroded down or the base metal was so soft it hammered them in. The third was a SMOKER. oil smoke, bad. There was about .5mm of play in EVERY guide. That head had 3K on it.
Junk....
Old February 11th, 2017, 06:14   #169
prsa01
Default Hans auto got me
To be clear, for anything engine related or mechanical/critical I always buy from the tdiclub vendors.
As per usual, should have checked here first. Got fooled by the "Hans auto" store front when quickly searching for a less critical part (door latch).
Live and learn.
Luckily it's "just" a door latch and is easy to change on the mkv but still hate to be sending any money his way. Will be more careful going forward.
'06 BRM Jetta; 5spd - ziptie mod
96 B4v
eCodes
prsa01 is offline   Reply With Quote
Old March 20th, 2017, 09:40   #170
skyking1
Thanks for the thread. My injection pump is going bad, and I ended up on hansauto site. It rang a bell......
thanks again!
skyking1 is offline   Reply With Quote
Old May 17th, 2017, 14:54   #171
quartersaw
Fuel Economy: Passat:44mpg Golf 52MPG
Originally Posted by quartersaw View Post
My BLAAST 'Billet turbo', which allegedly gave up to 30 lbs. of boost (per seller) lasted about 500 miles.
Had problems with the turbo from day one, and was fed a stream of B.S. by the seller.
BLAAST has ignored my e mails for warranty coverage.
I replaced it with a VNT-17, and have had no problems.
If you buy a BLAAST turbo, you are throwing away good money.
(I'm running a Malone Stage 4 tune)
A sad bump for this crook......
quartersaw is offline   Reply With Quote
Old May 19th, 2017, 19:22   #172
Abacus
That helpful B4 guy
Abacus's Avatar
Fuel Economy: And the miles just keep ticking away
thanks again!
I have one of these installed that I need to change out. It's an OEM pump that clearly has issues since it wanders all over the voltage map and throws codes. It is still working but isn't right. I have an old pump on the shelf that worked fine so I'll toss it on.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
'96 B4V: 356,000 miles Malone 2+, PP520's, 6 speed, 02J short shifter, E-Codes, G60 brakes, Evo plate, DMF, stainless exhaust, heated leathers, cold weather package
BUG*PWR 2013 Award Winner
Abacus is online now   Reply With Quote
Old June 29th, 2017, 09:38   #173
maxmoo
Whats the story on "Wolfsburg tuning"?
And the "Lubeck" brand parts they sell?
Any experiences?
https://www.wolfsburgtuning.com/
maxmoo is offline   Reply With Quote
Old June 29th, 2017, 10:26   #174
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Any experiences?
Prothe has Wolfsburg Auto Parts. Might be another of his shams.
-George Bernard Shaw
Old June 29th, 2017, 10:31   #175
jasonTDI
jasonTDI's Avatar
Someone else. But a mix of chinese and other aftermarket parts.
Old December 11th, 2017, 07:39   #176
AnotherPerson
TDI(s): 1999 Beetle
Was laying in bed thinking about this dude. Since he is very good at finding cheap stuff in China for our cars. Why the hell doesnít he get us some beetle door panels made? Cheap Chinese plastics canít be any worse than what vw makes them out of. And Iíd be fine paying him $150. Iím sure many others would since vw wants so much for them. Every time Iím looking for something non mechanical google links to him but he no longer sells it. Iíll take chinese cosmetic parts for 1/4th the price. Canít be any worse than cardone and dorman crap everybody here sells.
AnotherPerson is offline   Reply With Quote
Old December 12th, 2017, 11:00   #178
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
He kinda has a point though... A lot of his non critical products are no worse than what you get from most parts stores
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old December 12th, 2017, 11:30   #179
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
^ which supports his business and the likelihood that he will trash yet another innocent TDI'ers cylinder head with a timing belt he won't guarantee other than to replace it with another CRAP belt
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old December 12th, 2017, 11:30   #180
kooyajerms
grocery getter
kooyajerms's Avatar
Sure Jason, but the point of the thread is who's considered a "bad" vendor. We confirm that he is one and then to say, he can get an item cheap for us, let's contact him about that. The thread was based on treatment of customers, and I'd say supporting him on non critical items so he can keep supporting his critical item failures is a loss.
Screw you Windex, too fast
kooyajerms is offline   Reply With Quote
Vendor List TDIFest 2011 paramedick TDIFest 2011 20 September 2nd, 2011 20:04
Vendor List-where posted May-39 TDIFest 2008 5 August 5th, 2008 19:32
Vendor list brianteel TDI Power Enhancements 8 July 30th, 2006 08:26
Page generated in 0.17212 seconds with 13 queries
[Output: 136.32 Kb. compressed to 114.46 Kb. by saving 21.86 Kb. (16.04%)]
