SFHGolfTDI
- Joined
- Nov 3, 2003
- Location
- Ventura, CA
- TDI
- 2002 Jolf GLS TDI - Reflex Silver (purchased 2011) | Previously: 2001 Golf GL TDI - Indigo Blue (sold 2005)
Hi All,
I know I haven't met most of you since I haven't been able to make it to most GTGs. I'm in a bit of a pickle since this is our only car and I had to have it towed home last night after a bit of sputtering on the freeway and then the engine stalling with air in the fuel line. I don't have the tools or the knowledge necessary, and Matt can't get to me this week. I could tow it all the way to Harv, but would like to avoid that if necessary as I live in Santa Monica and we'd be carless. Here's my situation:
1) I had run the fuel tank down to about 1.5 gallons remaining in the tank (for me, about 685 miles). This is the lowest its ever been with me.
2) I refueled with B99 as usual (its been on mostly 50-100% biodiesel for the past 12k miles), venting to the brim with 15.5 gallons.
3) Left the fueling station, drove a few miles and got on freeway.
4) On the on ramp, decided to "italian tune" the car revving in 3rd gear, but noticed sudden sputter and loss of power when it hit 4k rpm.
5) However, it continued to drive mostly fine as I kept it around 2-2.5k rpm on the freeway, though I noticed a few sputters if I tried to push it.
6) As I got off the freeway 17 miles later and pulled off, the car sputtered and died as I rolled into a parking spot.
7) Popped the hood and discovered 2" bubble of air in fuel line.
7) Car turns but will not start.
VCDS returns the following error code:
1 Fault Found:
17656 - Start of Injection Timing Regulation
P1248 - 35-00 - Control Deviation
My thoughts: Could it be as simple as a blocked up fuel filter or bad gasket on the filter? Do you think the low tank kicked up some gunk that blocked my fuel sender or filter? Why would the problem not happen until after filling the tank, though? Does the "italian tune-up" have anything to do with why this happened at that moment (I've done plenty in the past with no incident)?
If anyone is around and able to come to Santa Monica, I would greatly appreciate it. I am willing to pay for competent help to get this thing running again.
Thanks all.
Shady
1 Fault Found:
Thanks all.
Shady
