I promised an update after I installed the Spec Stage 2 clutch, and a new stock dual-mass flywheel. For those that don't want to read the whole thread, I installed a stock weight G60 flywheel and new VR6 clutch kit back in December on my 2005 Golf. Hated it. The noise sucked, the buzziness throughout the rev range was annoying, and the clutch felt like a marshmello...and it was not a bleeding problem. That's just the way the VR6 clutch feels.
Took me about 7 hours this time start to finish, including setup and cleanup. One thing that I learned was to use CV joint moly lube on the three driver's side engine mount bolts. Much easier turning them in.
So I installed a new dual mass flywheel, and a new Spec Stage 2 clutch. My modern, refined, vibration free car is back. I love it again. The clutch grabs right where the new stock clutch grabbed. Close to the floor, but not too close. The clutch engages smooth as butter, and I can feel where it begins to take up. No shudder, or anything out of the ordinary. I think people that have problems with this Spec Stage 2, must not be cleaning the flywheel and PP properly. Clean it until a white rag doesn't show ANY dirt...that goes for any clutch install.
I didn't have to remove the pedal stop, and I didn't have to bleed the clutch since I made a point of keeping the slave cylinder below the master.
Love the clutch. Time for Kerma.
