Old January 13th, 2020, 06:28   #1
eddie_1
eddie_1's Avatar
Default Put VNT22 housing on GT1749VB?
I was looking to replace the 17/22 I brought from the US with a GT1749VB but the old 17/22 compressor housing is VNT22 like on VW T4, so my existing custom hoses don't match up. Would it be ok to just put the VNT22 compressor housing on a new GT1749VB or is it a problem that it is bigger? Thanks in adavance!
2008 A6 BPP 283kmh - 100-200 kmh 14 secs - 2003 Jetta Wagon ALH 150mph, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old January 13th, 2020, 09:55   #2
flee
flee's Avatar
Fuel Economy: 40-ish
It isn't just the housing as you would need to change the impeller as well, right?
In which case you won't be able to balance the rotating assembly on your own.
2002 Jetta GLS TDI wagon
flee is online now   Reply With Quote
Old January 15th, 2020, 03:56   #3
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Needs compressor wheel, backplate and housing plus balancing and calibrating VNT setting afterwards.
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old January 15th, 2020, 04:20   #4
eddie_1
eddie_1's Avatar
Thanks for the feedback guys. Sounds like the compressor wheel needs to match the housing for things to work properly.
Can you put a VNT Housing on a Ball Bearing CHRA goodlun TDI Power Enhancements 1 May 15th, 2011 01:54
Clocking GT1749VB Exhaust Housing imtryin TDI Power Enhancements 2 March 27th, 2011 19:37
1.9 PD 150 with VNT22 Sufitdi TDI Power Enhancements 12 March 12th, 2008 04:04
What did Jiffy Lube put in my oil filter housing? TrogDorInjection Fuels & Lubricants 53 September 17th, 2007 19:17
To those of you with vnt22's.. LNXGUY TDI Power Enhancements 14 May 24th, 2007 04:28
Page generated in 0.12070 seconds with 13 queries
[Output: 65.88 Kb. compressed to 58.96 Kb. by saving 6.92 Kb. (10.50%)]
