d@g
As part of my ongoing my-car-wont-start problem, I opened up the top of the injector pump ('02 Golf TDI/ALH) because I had an OBDII error (P1562), which I read here indicates a fuel temp sensor error. (Since I was a BD user in the past, I also wanted to look inside the pump to see its condition -- it was pristine, btw).
Anyhow, not having the Metalnerd bit to loosen the triangular bit, I took the advice of cutting a slot with a dremel into the bolt head to remove it with a screwdriver.
Does anyone know the specs (size, length) of the replacement bolt and if I can get something like that (hex or torx head) from a home depot or Lowes?
