Old March 25th, 2020, 05:43   #1
elroustom
Default Rocky Start ... or none at all!
Hello all, new here, new owner of TDi 2014 SportWagen
4 days into owning the certified car and it wouldn't start (stuck at work) had to call road-side assistance to tow it.
First it said key was too far away. Then when I put the key on the button and pushed, all sorts of lights came on and lot of beeping, and error messages, errors, brakes, air bag, service now ... and I couldn't even close the moonroof.
Did I buy a lemon? Is this something that's a part replacement, or is this indicate a system wide failure that no amount of visits to shop will fix? Any thoughts. Or could it be something as simple and stupid as a dead battery?
The 2012 Golf I traded in (217,000 miles) always started and ran like a champ. I just didn't want to risk any issues because the next two years I need a reliable car that's not going to cost outside of budget.
Just so I'm prepared for whatever the dealer is going to tell me, I'd appreciate input from this group, if any comes.
Thanks!
elroustom is offline   Reply With Quote
Old March 25th, 2020, 06:43   #2
IXLR8
When I bought my 2014 Sportwagon, the battery was dead about 8 days after I got it home. First thing I would do if I were you, get a meter and measure the battery voltage. If it is less than 11, put in a new battery.
I don't know where in MA you are, but I would stay away from Patrick VW.
Jim Peck
'14 TDI JSW 6M, Blue, 39,980 miles
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 298K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear. Failed safety inspect for rust
IXLR8 is offline   Reply With Quote
Old March 25th, 2020, 20:03   #3
elroustom
I'm on the South Coast, but inland. Coastal VW in Hanover went all the way to Raynham to pick up the car from VW dealer the roadside assistance towed it to, and they got right to work on it. Seems It needed a whole new push-button starter assembly. Not just corroded contacts. Should be ready tomorrow. I'm impressed by their service. The inconvenience is just that ... I'll live. I will ask about the battery when I pick it up. Thank you.
Old March 26th, 2020, 08:24   #4
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
Mine died the morning after purchase. A 6+ year old battery that has sat for a year is a common failure.
I bought the top autozone battery and requested the dealer cover it. I also noted that the previous work order had a side note that the battery had to be jumped... They covered cost. You just bought it!
JELLOWSUBMARINE is offline   Reply With Quote
Old April 2nd, 2020, 07:26   #5
IXLR8
It was easier to just buy the battery than deal with a 4 hr round trip to the dealer, plus the time dealing with the dealer. That dealer also wanted to charge me $600 to fix an issue that I fixed for $25. Never returning there again.
Jim Peck
Parsons Branch: One Rocky Road TrogDorInjection Road Trips 2 June 19th, 2012 16:42
USAFA and Rocky Mountains slfranke Sightings 0 January 17th, 2006 11:49
Rocky Mountain Biodiesel? aw Mountain/Southwest States 10 July 28th, 2005 20:25
Rocky Mountain GTG Montana diesel West Coast Canada/USA 13 September 29th, 2002 00:42
Rocky MTN GTG Montana diesel West Coast Canada/USA 0 August 6th, 2002 17:27
Page generated in 0.08946 seconds with 12 queries
[Output: 71.88 Kb. compressed to 63.96 Kb. by saving 7.93 Kb. (11.03%)]
