mmm not sure on this one http://www.youtube.com/watch?v=22bfF9BLrV0&feature=g-upl
Youve deleted the dpf, you dont need that sensor or the pipes.rite so i need a few bits to finish the project .
i need two pipes that run from the downpipe to a sensor on the left of rocer cover, dpf balance pipes i deleve .
so i go to vw , you will love this ,, if you want the two pipes that on the pic show they are not fixed , they bolt in . they have there own item number but only one part number . cool i think they must come togeter......... oh yeah they do £1700.00 ,, you can only get them with the dpf in the uk, no bolts ,no sensor ,no rubbers , nothing ( rhd )..
BUT,,,, for the same car in lhd £94.00 an they come with all the bolts an rubber pipes for fitting .
how can they do that to us ?
isnt it the same engine left to right hand drive ?? parked one next to the other an they look the same , pipes run the same route an everything .
yes dpf deleted but without the sensor conected it just kept coming up on vag com, once fitted even thou not working its fine . very odd i know but thats what it was doingYouve deleted the dpf, you dont need that sensor or the pipes.
Did you have the dpf deleted with a tune? If so they have missed deleting the sensor.yes dpf deleted but without the sensor conected it just kept coming up on vag com, once fitted even thou not working its fine . very odd i know but thats what it was doing
yes i did , an that is a fair point but , when i go in a look at the sensor on the vagcom it says OFF , but im going to have it looked at as i have a problem .( see post )Did you have the dpf deleted with a tune? If so they have missed deleting the sensor.
well if you need a car to test ;-) ;-) you know where I amLooks nice!
We are doing a bit of testing on the CR engines ATM, i've fitted 2260's to them but value per HP will be better with the ideas we have in mind!
Last time op was here is 2013.looking to do the same conversion on my van. but from a leon fr 170. what is the wiring like as it's the only part I feel I'll struggle with
