NoelMcC
Hi Correction not 01E but O21
Hopefully someone has done what Im attempting to do.
I have an Audi O12 style transmission code FHN and was wondering if the ring and pinion are the same size and dimensions as used in an Audi A4 1.8 T O12 gear box .
I understand the final drive ratio will most probably be different but can these parts be interchanged . Can I use a 1.8 T pinion shaft and ring gear in my Tdi box.The pinion shaft is the main shaft and has all the gears running on it.
Noel
Noel
