Joe Campbell
OK, I think another post may have solved this problem for me potentially but just to see if anyone else has any other ideas about this I thought I would post.
Heres what I have got. The problem is intermittant. Every now and again when the moon aligns the car will stall for no good reason. It could be driving perfectly and then stall or be sitting at a light and just poop out. If left to its own devices about 20-30 seconds later the car will be able to be re-started. However if you try to restart it right away it will just spin forever never actually turning over (As if there were no fuel being injected).
In addition to this, when the car stalls the dash lights are different... under normal start conditions the car will have the pre-heat and check engine light lit... the pre-heat goes out and the car can be started - when the car stalls... if you turn on the key the pre-heater light and Check light don't come on - which is how I can tell when I will be able to re-start the car again. Anyone that may have the answer to this one - I would be forever greatful as the dealship in my area charges an ARM AND A LEG (
) for service.
Thanks in advance,
Joe Campbell (If you could post and respond to me via email that would be great.)
Joe Campbell
jcampbell@inventa.com
joercampbell@comcast.net
Thanks in advance,
Joe Campbell
