PDJetta
- Joined
- Nov 6, 2003
- Location
- Northern Virginia
- TDI
- '04 Jetta GLS TDI Pumpe Duce Platinum Grey w/ Leather
Starting about a month ago I noticed a slight whirring/whine sound coming from the final drive portion of the drivetrain. Its "noticeable" and may be normal, I'm just not sure. Its a fairly faint sound, almost like the meshing of the gear teeth. Its odd that the first 65,000 miles of the car's life the sound was not there. I say the "final drive" because the tone of the noise varies directly with road speed, not the engine speed. If I shift gears from 5th to 4th, the tone is the same, although its quality is slightly different. I do think it is coming from the transaxle.
Its most noticeable when in 4th or 5th gear with a very slight loading of the engine. Push the accelerator slightly more, the sounds fades out, or let off the accelerator (engine over-run), the sound fades out too.
If abnormal wear is causing the sound, there are only two causes related to me I can think of:
1. I coast in neutral alot. Up to lights when I need to only slow gradually, coming up to turns and turn and put it in gear again, etc. I wonder if this in some way could damage the transaxle by preventing proper lubrication (slinging the oil inside) of the geartrain.
2. At 50,000 miles I changed the gear oil (with the same G052 gear oil) and only put 1.5 liters back in (that is all it would hold when I leveled the car, but I forgot to run the car in gear for a few minutes and recheck the level, per Bentley) and I wonder if the transaxle is a cup or two too low, but I reason even if slightly low, this should not cause damage.
Any thoughts? Anyone elese have this slight drone from their transaxle that I hear? Its almost a normal sound, but I've only noticed it recently.
Thanks.
--Nate
Thanks.
--Nate
