Melting tail light bulbs repeatedly
DidJettarun
South Carolina
A5 2005.5 Jetta A4 2003 Jetta
Hi All
Been a while since my last post but my 2005.5 Jetta has decided to start burning up right tail light bulbs. Pull bulbs and the bases on the bulbs are melted to the point that the access to the inside of the bulb is open. I have replaced 6 bulbs in the last couple of months.
Cleaned the contacts very thoroughly before last replacement and 3 days later bulb bases burned off....
Always the right tail light both bulbs
Thoughts
JETaah
Vendor , w/Business number
mi 48836
96 B4V, 1999.5 jettaIV,2005 BEW Beetle
Just some ideas here...
Chinese bulbs?
Wrong bulb with a higher wattage maybe?
Tail light bulbs are meant to be on for long periods of time. Brake light and turn signal bulbs are only on intermittently. Being that the latter are brighter and higher wattage they create more heat. To mistake the two can melt the fixture plastic, too.
