EJS
So after my second TDI I finally decided to get VCDS.............ran a scan and found a (couple) of codes.
I know what the priority means, mileage, etc but what exactly the code means in english is a mystery.................any input would be appreciated -
2 Faults Found:
005079 - Cylinder 4 Internal Pressure Sensor: Short to Plus
P13D7 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 4
Mileage: 36173 km
Time Indication: 0
Date: 2000.00.00
Time: 06:16:33
Freeze Frame:
RPM: 1840 /min
Speed: 56.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 0.0 bar
(no units): -12.80
Ign. Timing: 0.4 °BTDC
(no units): 4.00
005081 - Cylinder 4 Internal Pressure Sensor: Implausible Signal
P13D9 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 35971 km
Time Indication: 0
Date: 2000.00.00
Time: 06:04:14
Freeze Frame:
RPM: 1863 /min
Speed: 94.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 83.0 bar
(no units): 11.80
(no units): 4.00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 36173 km
Time Indication: 0
Date: 2000.00.00
Time: 06:16:33
Freeze Frame:
RPM: 1840 /min
Speed: 56.0 km/h
Bin. Bits: 00001010
(no units): -12.80
(no units): 4.00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 35971 km
Time Indication: 0
Date: 2000.00.00
Time: 06:04:14
Freeze Frame:
RPM: 1863 /min
Speed: 94.0 km/h
Bin. Bits: 00001010
(no units): 11.80
(no units): 4.00
