Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old February 14th, 2011, 20:08   #211
dubStrom
dubStrom's Avatar
Originally Posted by Jack Frost View Post
Perhaps we need to look at the HPFP in the same way as the timing belt. Change it before it fails.
After warantee expiration, it would be highly advisable. And meanwhile, keep an eagle eye out for metal flakes in the filter recess.
I am hoping that the better pumps will be a permanent fix (or at least good for 100k+ if doping with lubricity agents).
It is really screwy that a HPFP cannot be manufactured. I would pay more for one that doesn't shred itself apart. How about aftermarket?
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline   Reply With Quote
Old February 14th, 2011, 21:33   #212
dzcad90
Rolex & gin
dzcad90's Avatar
So $800-1K for a timing belt, $1800+labor for a fuel pump all while staring down both barrels at a possible DPF replacement at anywhere between $1-2K.
Yeah, that's realistic.
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Old February 14th, 2011, 22:06   #213
pleopard
pleopard's Avatar
Is the HPFP itself really $1800?
'10 Jetta 2.0 TDI, DSG
pleopard is offline   Reply With Quote
Old February 15th, 2011, 04:33   #214
El Dobro
El Dobro's Avatar
Fuel Economy: 115 MPGe
It can be had for under $1000 discounted, but as a maintenance item? BS. There goes your fuel savings out the window.
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is online now   Reply With Quote
Old February 15th, 2011, 04:34   #215
Scratcher
Scratcher's Avatar
Once the aftermarket re-builders get there hands on a few it will probably be around the $1000 mark
http://www.thedieselstore.com/templa...11172631117792
2011 VW Sportwagen TDI
1984 Ford F250 6.9 IDI (Diesel)
2012 Subaru Outback Premium 6sp MT
Scratcher is offline   Reply With Quote
Old February 15th, 2011, 04:37   #216
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Impex lists the VW list price on a 03L130755A pump as $1265.
And, I still say, aftermarket (that is, non-Bosch) isn't really the true answer - if there's a 1800 bar version of the Bosch CP3.2, that's the answer. (Or, for that matter, use a CP3.3, and just have the thing bleeding fuel off all the time. You'll have enough fuel for 450 hp, but you don't have to use it all...) That's a pump that is more tolerant of US fuel.
Also, $900 for a VE pump has no relation to what a CR HPFP will cost.
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline   Reply With Quote
Old February 15th, 2011, 04:59   #217
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
The crack spread hit $.70 per gallon (i.e. difference between rug and diesel). There is no savings for the lower mpg CR engines right now.
I don't hold one ounce of sympathy for VW. Is the claim that VWOA is/was too stupid to understand that the USA runs state of the art 1950s infrastructure. They should have expected it and developed a pump for it --- oh wait, they did in every design but the CR's .........
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old February 15th, 2011, 05:56   #218
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Actually, the 2.0T eats HPFPs, too.
(IIRC, the reason for gasser HPFPs dying is ethanol.)
Old February 15th, 2011, 06:30   #219
Scratcher
Scratcher's Avatar
Originally Posted by bhtooefr View Post
And, I still say, aftermarket (that is, non-Bosch) isn't really the true answer - .
I wouldnt be so sure about that. Pensacola made a far superior update to the Stanadyne DB2 for my 6.9 IDI. The original lasts about 160.000 whereas the Pensacola with updated internals will outlast the original for many more miles.
Old February 15th, 2011, 07:13   #220
lcjjm4
Default 3x designs
BMW had a recall on its HPFP thanks to a 20/20 report on ABC. I spoke to a BMW rep they are now on there 3rd replacement pump since the recall the others all failed. As per Friday 2/11/11 one of there salesman has 12k miles in just under 2 months an still working ok.
I also recently spoke with a Regional mgr for Bosch an he will get back to me on the VW issue sometime this week.
I called VW of N America on the HPFP problem, well they state its a fuel contamination water or gas mixed in the diesel fuel. I cam back and said well how come there is no contamination on the 06-08, only 09-10 her answer was pure silence.
The more people complaining the better off for all TDI owners
lcjjm4 is offline   Reply With Quote
Old February 15th, 2011, 08:44   #221
gpshumway
TDI(s): 2000 Jetta
Unless there's a failure mode I'm unaware of, it can't be ethanol or other fuel related reasons, the FSI engines have oil lubed HPFP cams. The newer TFSI engines have supposedly solved the problem by switching to a roller follower.
gpshumway is offline   Reply With Quote
Old February 15th, 2011, 09:39   #222
MonsterTDI09
MonsterTDI09's Avatar
I'll be quite upset if my pump fails soon after the warranty runs out at 60,000 miles. I mean, if it fails at 200,000 miles, fine, but if it fails and takes out $10K worth of fuel system components... That's just not acceptable. The effect of failure strikes me as a bigger issue than the failure itself...
+1 This is real problem they should work on and the pump to.It's one thing for the pump to fail but to take out the whole system is a downer.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is online now   Reply With Quote
Old February 15th, 2011, 11:43   #223
Dariof
Dariof's Avatar
TDI(s): 2011 JSW TDI
Fuel Economy: Whatever the Highest Number Was. That's It.
I am on the sidelines in purchasing a new TDI Wagon because of this issue. I do believe VW makes a great car, will get this handled and will have a permanent fix, but I also believe it will take a little while longer for this to happen.
However, there are way too many posts on the subject, both within this forum and outside sources.
Although nobody is exactly sure of how widespread this issue has become, there is no doubt, it is an issue.
These failures are not a state of mind, and I highly doubt they are all caused by diesel enthusiasts "accidentally" putting gasoline in their tanks.
My local dealer told me they have had 4 failures, and all were because the diesel purchasers didn't know any better and put gasoline in the tank. I know that is not true, and it fits nicely with VW's stance of "plausible deniability."
In the meantime, I'll continue to drive my German Diesel SUV around until I believe VW has fixed this issue.
Best Regards, DarioF
1954 Spaceship (In My Avatar)
2013 Porsche Carrera S CAB
2008 Mercedes GL 320 CDI (Diesel)
Dariof is offline   Reply With Quote
Old February 15th, 2011, 12:07   #224
Second Turbo
Fuel Economy: 38
Default Mis-fueling
Dariof: > My local dealer told me they have had 4 failures,
> any better and put gasoline in the tank. I know that is not true, ..
Doesn't matter. Even if it were true, mis-fueling is going to happen.
And it can happen at the terminal, when re-filling the retail
station, or when filling the vehicle.
In the past, it often resulted in nothing in particular,
or maybe a blown head gasket. It did not cause mass
destruction of the fuel system.
_______
The HPFP is apparently not designed for the real world
(US lubricity or predictable mis-fueling - or both).
Second Turbo is offline   Reply With Quote
Old February 15th, 2011, 12:23   #225
scdevon
scdevon's Avatar
TDI(s): None
Fuel Economy: Awesome
_______
Unless you filter the fuel LEAVING the high pressure port of a HPFP, a failed pump will tend to destroy the fuel system. There are very few options to filter the fuel leaving a HPFP at 1800 bar.
Perhaps a sintered bronze filter integral in the high pressure fuel line between the HPFP and the common rail would withstand that kind of pressure, but not much else would. This would not be a maintenance item, but a fail safe item. The metal particles leaving the trashed pump would lock up the bronze filter and stall the engine before the metal reached the common rail and the rest of the fuel system.
scdevon is offline   Reply With Quote
HPFP Failure in V6 TDI, or only in 2.0 CR? Trooper81 Fuels & Lubricants 65 May 30th, 2014 19:52
CR High Pressure Fuel Pump "HPFP" failure FAQ - Updated 2/8/2011 dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 June 28th, 2010 14:52
Good Job! NHTSA investigation candywhite VW MKV-A5 Golf/Jettas 15 July 28th, 2009 03:26
NHTSA opens investigation on DSG transmisisons dieselyeti VW MKV-A5 Golf/Jettas 1 July 24th, 2009 12:07
Page generated in 0.24367 seconds with 11 queries
[Output: 138.56 Kb. compressed to 116.74 Kb. by saving 21.81 Kb. (15.74%)]
