Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old February 14th, 2011, 08:47   #166
scdevon
scdevon's Avatar
TDI(s): None
Fuel Economy: Awesome
Originally Posted by Absolute Diesel View Post
Hopefully we get a recall, new redesigned HPFP's in all of our TDI's and in the 11's going forward and we can put this problem to bed.
There is no way VW is going to replace everyone's HPFP as a preventative measure. At this time the failure rates aren't steep enough for them to be forced to do so, either. There will be a certain amount of goodwill and a secret warranty from VW if you have a pump crap out that was from the weak production run. That's the cheapest way for VW to handle this.
A year or two from now, we will know that Bosch and VW were scrambling behind the scenes to fix this with the late 2010 and 2011 cars. The "revisions" of the fuel pumps probably include additional hardening of the pump cam, plunger roller and plunger with possible application of anti-friction coatings.
I know that the 2011 cars don't have as many miles on them, but this problem seems to be going away with the pump revisions.
scdevon is offline   Reply With Quote
Old February 14th, 2011, 08:47   #167
MonsterTDI09
MonsterTDI09's Avatar
The dealer ship were I bought my car uses TDI as loners.I guess a couple put of customers put gas in them.Now they a magnet that say diesel fuel only in bright letters.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Old February 14th, 2011, 08:49   #168
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
What kind of nut a that dealership gave out TDI's as loners?
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old February 14th, 2011, 09:38   #169
tsdevine
Default Well...
Originally Posted by bhtooefr View Post
The 460 rating is an absolute maximum, no leeway - Bosch recommends 400, actually.
I'd love to see how that goes in an engineering review. It's akin to selling a gasoline car advertised as requiring regular gas, then later finding out if you don't use >100 octane racing fuel it may cause serious damage to the engine. (I'm sure someone will have an issue with this analogy but...)
I'm not sure how the NHTSA can just ignore that fact. The VW CR engine hasn't been out long enough to get a good long term sampling of pump failure rates. Given the manufacturer says is must be less than a 460 scar rating and US specification is 520 (and lubricity isn't labeled at the pump like octane is for gas, so there's no way for a consumer to know), I just don't see how that gets past an NHTSA engineering review. (Granted you could make the argument that it shouldn't have made it past internal VW reviews.)
I'm probably oversimplifying this, but if the pump by design can't handle US diesel and subsequent wear can lead to catastrophic failure (and catastrophic failures are happening), the how could the NHTSA write that off?
tsdevine is offline   Reply With Quote
Old February 14th, 2011, 09:53   #170
dzcad90
Rolex & gin
dzcad90's Avatar
The engineers at Bosch and VW aren't idiots. What's likely the issue here is that the pump that was re-engineered to be compatible with US fuel lubricity standards, however that engineering effort just didn't work out as well as it was intended to, hence the redesigns.
This theory would probably shed some light on why the pump that is installed in engines destined for the European market has a different part number.
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Old February 14th, 2011, 09:57   #171
tsdevine
True, but if you and I can figure that out.....given the number of revisions that have been made to the pump, you'd think the NHTSA review process would figure that out as well. I just find it hard to believe it would just sweep that under the carpet.
Old February 14th, 2011, 10:00   #172
LRTDI
Which makes me wonder if Euro spec HPFPs were built into a small number of US or North American bound TDI engines
LRTDI is offline   Reply With Quote
Old February 14th, 2011, 10:02   #173
ZiggyTheHamster
ZiggyTheHamster's Avatar
When talking about the wear scar rating.. are we sure this is what applies to our pump? Being an international company, I can see BOSCH wants everyone at 400-460, but still designs a pump that more or less runs on our crappy fuel. I haven't seen any specifications for our pump (perhaps I should call a BOSCH distributor in the area). That has to be the difference between the non-US and the US pumps (perhaps it's non-North America and North America - I have no data from Canada).
Also... To me, the fuel pump in any car is a wear item. It will eventually fail. I've had fuel pumps in at least 3 cars fail (granted, these were my dad's cars, since I wasn't old enough to drive then). It happens. Why didn't VW design the fuel system such that a failure can't take out the entire system (granted screens won't help much with metal flakes)? Does anyone know if VW revised the design of the system in the MkVIs?
2009 VW Jetta TDI - Black w/ DSG Born: 5/2009
DSG Paddle Shift Steering Wheel
RCD-510 Stereo
9W2 Bluetooth
ZiggyTheHamster is offline   Reply With Quote
Old February 14th, 2011, 10:04   #174
ZiggyTheHamster
You said it just before I posted it... That's what I think too
Not from my data so far.
RCD-510 Stereo
9W2 Bluetooth
Old February 14th, 2011, 10:10   #175
oilbug
From an earlier post in this thread, I thought the difference in part numbers was only at VW and the Bosch part number was the same for both markets, did I understand correctly? If so, this can't be a mixed up production line issue. In any case, unless there was a really significant difference in cost per unit, I'd be surprised if Bosch/VW/Audi would carry two lines of different pumps, it costs money to do so...
oilbug is offline   Reply With Quote
Old February 14th, 2011, 10:25   #176
ZiggyTheHamster
The BOSCH part number is different between the two pumps (non-US, US). Same model number though.
RCD-510 Stereo
9W2 Bluetooth
Old February 14th, 2011, 10:31   #177
Jedadiah
Jedadiah's Avatar
Spiegel.de. Germany's biggest magazine (akin to TIME here) mentioned the investigation on their website today.
http://www.spiegel.de/auto/aktuell/0...745232,00.html
Jedadiah is offline   Reply With Quote
Old February 14th, 2011, 10:40   #178
studhilo
Default But - What if ????
Here is a question... What if VW were to admit the problem and/or the government forced a recall of all of our cars today? Would VW have a solution? Is the current pump model the one we want or will there be several more upgrades until they get it right?
studhilo is offline   Reply With Quote
Old February 14th, 2011, 10:43   #179
jbright
VW is still blaming gasoline-contaminated fuel as the only problem, even to their home audience. I'm not sure what previous 2010 fuel line re-call this article refers to at the end. . . my German's pretty rusty and the Google translator was not very precise.
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed' 10/18.
47.8 mpg best tank, all interstate @ 70 mph ----- 162,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
Old February 14th, 2011, 10:52   #180
scdevon
scdevon's Avatar
TDI(s): None
I don't see them producing two different spec pumps either. It's worth mentioning that quality control of ULSD in the U.S. probably wasn't all that great in the beginning and still might not be that great now; particularly with regard to wear scar rating. Europe probably has a leg up in Diesel fuel quality which could explain why pumps don't seem to fail in Europe as much.
In the early days of ULSD, it seems as if we had to rely on some "Bubba" at a fuel terminal to add enough precious lubricity additive to get our fuel to an unimpressive 520. A 460 rating is obviously better. A HPFP would probably operate for 30 years with 300 scar rating fuel. What wear scar rating does fuel have with no lubricity added at the terminal? 1000? 1500?
HPFP Failure in V6 TDI, or only in 2.0 CR? Trooper81 Fuels & Lubricants 65 May 30th, 2014 19:52
CR High Pressure Fuel Pump "HPFP" failure FAQ - Updated 2/8/2011 dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 June 28th, 2010 14:52
Good Job! NHTSA investigation candywhite VW MKV-A5 Golf/Jettas 15 July 28th, 2009 03:26
NHTSA opens investigation on DSG transmisisons dieselyeti VW MKV-A5 Golf/Jettas 1 July 24th, 2009 12:07
Page generated in 0.25605 seconds with 13 queries
[Output: 138.79 Kb. compressed to 117.43 Kb. by saving 21.36 Kb. (15.39%)]
