to bad the aholes always show up just looking for help to fix my car i am new to tdi,s i thought that is what this forum was for ???????????
Sorry to nitpick, but your posts lack the punctuation necessary to make yourself understood.
Have a look at what a few dots and comma's can do to change a paragraph:
What you wrote:
ok lets see if i changed the right one i did the one in the hose and the one at the plastic inlet i see one more sensor at the end of the block a single wire bass screw in one is that the one for the temp gauge the gauge has been reading less and less for the last year as i drive it the gauge goes up a little and the light goes out should i change the brass one thank for any input mike
What it should look like:
Ok. Let's see if I changed the right one. I did the one in the hose, and the one at the plastic inlet. I see one more sensor at the end of the block: a single wire brass* screw in one. Is that the one for the temp gauge? The gauge has been reading less and less for the last year. As I drive it, the gauge goes up a little and the light goes out. Should I change the brass one? Thank you....
Isn't that just a touch easier to understand than what you wrote?? I am no English major, and don't pretend to be smarter than anyone else here but to me, if I can find a way to better describe my problems I figure it'll make for an easier fix.
I have to say, this Ontario forum has some of the most helpful people you will find anywhere.
