Old August 1st, 2020, 14:26   #1
PakProtector
Default 240mm 02A/J Clutch?
hey-Hey!!!
Just found this on the interwebs:
https://www.fourseasontuning.com/dcs...rsion-kit.html
Assuming the flywheel is heavy enough, can this work on an ALH/BEW?
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old August 1st, 2020, 15:29   #2
Nero Morg
Nero Morg's Avatar
But why, when a South bend stage 2 is competitive in price?
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old August 1st, 2020, 18:57   #3
PakProtector
Rest assured, if I wanted to talk about 'who has the most ft-lb/$', or 'who makes your favourite clutch', or 'what clutch should I buy' I would have phrased the question differently...
cheers,
Douglas
Old August 1st, 2020, 19:21   #4
WildChild80
WildChild80's Avatar
I'm with you...if something works I stick with it.
Sent from my SM-N975U using Tapatalk
WildChild80 is offline   Reply With Quote
Old Yesterday, 04:59   #5
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
VR6 flywheel won't work, wrong bolt pattern.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old Yesterday, 05:56   #6
PakProtector
Now that is what I was looking for...
Douglas
240mm 6 speed clutch Gazg1986 TDI Power Enhancements 13 September 26th, 2019 03:32
240mm O2J Clutch PakProtector TDI Power Enhancements 2 November 14th, 2018 17:39
240mm clutch, sensible power limit? passartist VW B5 Passat TDIs 2 May 7th, 2016 14:37
240mm Clutch/DMF PoochiePD Private TDI Items for Sale/Wanted 5 February 23rd, 2012 14:03
6 speed clutch options 240mm Shenandoah TDI Power Enhancements 7 October 30th, 2010 17:52
Page generated in 0.12344 seconds with 13 queries
[Output: 76.24 Kb. compressed to 66.76 Kb. by saving 9.49 Kb. (12.44%)]
