Old June 22nd, 2020, 19:42   #1
cb1
Default 2005 passat throttle flap
https://www.ebay.com/itm/184324674141
does anybody know if this will fit my car...?the part# matches but the car it fit doesnt
cb1 is offline   Reply With Quote
Old June 23rd, 2020, 23:04   #2
DeliveryValve
Can't help you on the eBay part verification, but that flap has nothing to do with throttle.
- Richard-
2005 Passat TDI GLS Wagon 22x,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old June 24th, 2020, 09:42   #3
50harleyrider
that lap controls airflow and is indirectly a part of throttle. It is controlled by the ecu , not your foot. I just replaced one on one of my passats
50harleyrider is offline   Reply With Quote
Old June 24th, 2020, 10:06   #4
DeliveryValve
It’s actually called a Regulating Flap or also known as an Anti-Shutter Valve (ASV). The flap works in conjunction with the EGR, and it smooths (no shutter) the shut down of the engine in closing off air into the cylinders. It can also help in shutting down a runaway diesel.
If you can trick/reprogram the computer, you can run the engine without a regulating flap, but I wouldn't do it for safety sake.
- Richard-
Old June 24th, 2020, 18:59   #5
cb1
i know what it does..i have a check engine light on because of it...if i leave it plug in the car runs poorly,right now i have it disconnected...planning to sell the car but would like to fix it before i do..i believe the ebay part is from china...
Old June 24th, 2020, 19:00   #6
cb1
did you buy it from the dealer??i can get a used one for $120 but no warranty...
Old July 2nd, 2020, 18:38   #7
cb1
Originally Posted by DeliveryValve View Post
Itís actually called a Regulating Flap or also known as an Anti-Shutter Valve (ASV). The flap works in conjunction with the EGR, and it smooths (no shutter) the shut down of the engine in closing off air into the cylinders. It can also help in shutting down a runaway diesel.
so my car runs ok with it disconected but when i plug it in it idles rough...is that a common symptom??i just need to make sure before i spent over $300 for a new one...
Old July 8th, 2020, 08:58   #8
DeliveryValve
I would assume it would be the issue. But what does obd2 say?
- Richard-
Old July 8th, 2020, 10:24   #9
oilhammer's Avatar
Fuel Economy: fantastic
You need to diagnose your problem.
Semantics aside (different manufacturers call this part different things), it is there to increase EGR flow as its primary purpose on that engine. So chances are something is wrong with the EGR (which is a different part) and/or the MAF (another part) or a bad leak somewhere.
But the regulating flap can also do some strange things if the internal electronics get messed up. Your specific DTC would be helpful, but on the BHW if it has a regulating flap position related DTC, then chances are pretty good it is in fact the problem. Never seen a BHW have a wire harness problem like the BRMs do.
So yes, that eBay part looks to be the one, but I would not get anything like that from a place like that. I'd get the real deal from a reputable place.
www.cardocautomotive.com
Old July 10th, 2020, 20:49   #10
cb1
issue started after i put the egr cooler back so i will check the egr valve first...the code was for the asv if i remember correctly but not sure...will check the codes also whenever i get time..thanks everybody for the advise....
Old July 17th, 2020, 18:43   #11
cb1
ok..so had too many fault codes stored that i created by disconnecting the egr valve,regulating flap and maf....the egr was sticking open,i cleaned it and now it closes on its own,put it all back together,cleared codes and so far so good...i did have some hesiation,rough idle this morning but no check engine light so far...i have a generic scanner with me so next time it acts up ill be able to check it right away...
Old August 1st, 2020, 19:16   #12
cb1
codes for glow plugs came back,found 2 bad ones and replaced them...so far no check engine light but at times it idles rough,specially cold starts...i rev the engine and it idles ok...seems to be geting worse but without a check engine light not sure what to do..
Old Yesterday, 00:41   #13
afarfalla
afarfalla's Avatar
where in Texas are you and how much you want or the car the way it is
afarfalla is offline   Reply With Quote
Old Yesterday, 16:16   #14
cb1
in houston...will put it up for sale soon...will ask $3800 for it...
throttle flap for 2005 passat cb1 Private TDI Items for Sale/Wanted 2 June 23rd, 2020 04:14
Looking for Intake Flap (ASV, Throttle body, etc) jhs Ontario 5 May 30th, 2013 18:56
Replacing throttle body - 2005 Passat TDI gorsuchmill VW B5 Passat TDIs 10 August 16th, 2011 04:10
Anyone got an intake throttle flap motor? manics01 VW MKIV-A4 TDIs (VE and PD) 5 March 9th, 2011 18:49
removed throttle flap-still smokes joevat TDI Power Enhancements 27 July 29th, 2007 10:44
Page generated in 0.16208 seconds with 13 queries
[Output: 114.01 Kb. compressed to 94.93 Kb. by saving 19.08 Kb. (16.73%)]
