Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old July 21st, 2020, 18:08   #1
tdiman
tdiman's Avatar
Default glow plug light
Anyone no why glow plug light blinks puts car in reduced power turn car off and all is good again light goes off to you hit a hill again any ideas ?
tdiman is offline   Reply With Quote
Old July 21st, 2020, 19:42   #2
Vince Waldon
Vince Waldon's Avatar
The flashing glow plug light is a "fix me RIGHT NOW" urgent check engine light.
There are many possible causes ranging from burnt-out brake lights to issues with the injection pump. You need to find someone with a VW-specific scanner to scan for codes, and then you'll know exactly what to do.
Since you're experiencing power issues it won't be the brake lights. Could be pump, could be turbo. Code(s) will be an important clue.
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old July 22nd, 2020, 03:59   #3
Tdijarhead
From an old post years ago by MoGolf.
Flashing glow plug light
The flashing glow plug is sort of a super "check engine light". It flashes when the ECU detects that certain very important components are out of spec.
Per a post by MoGolf, the codes that cause a flashing glow plug light are below.
00741 Brake pedal monitoring - implausible signal
01044 Control unit incorrectly coded
16705/P0321 Engine speed sensor - implausible signal
16706/P0322 Engine speed sensor - no signal
16955/P0571 Brake light switch (F) - implausible signal
17653/P1245 Needle lift sender (G80) - short to earth
17654/P1246 Needle lift sender (G80) - Implausible signal
17655/P1247 Needle lift sender (G80) - Open circuit/short to positive
17762/P1354 Modulating piston movement sender (G149) - electrical fault in current circuit
17969/P1561 Metering adjuster (N146) - control difference
17978/P1570 Engine control unit blocked
18020/P1612 Control unit incorrectly coded
18026/P1618 Glow plug relay (J52) - short to positive
18027/P1619 Glow plug relay (J52) - open circuit/short to earth
18040/P1632 Accelerator position sender - voltage supply
Old July 26th, 2020, 19:08   #4
tdiman
tdiman's Avatar
Getting theses codes that are not on list u0100 and p00bd
Old July 26th, 2020, 20:41   #5
Vince Waldon
VW-specific scanner or something generic?
Old July 26th, 2020, 20:42   #6
tdiman
tdiman's Avatar
Scan Guage
Old July 26th, 2020, 20:43   #7
Vince Waldon
Yup, you need something that speaks full-on VW (VCDS being many people's favorite)
Scangauge only speaks OBD2... a small subset of the codes VW speaks... and they don't always line up.
Old July 26th, 2020, 20:44   #8
tdiman
tdiman's Avatar
I was afraid of that
Old July 26th, 2020, 20:47   #9
Vince Waldon
There's a list here somewhere of people that have VCDS, by region... may or may not be accurate.
Some folks have had luck finding someone on their local Craigslist that is willing to do VCDS scans.
Or... if you're planning to wrench on your car going forward... think of it the same way you thought of your first metric wrench set. Just gotta have it.
Old July 26th, 2020, 20:54   #10
tdiman
tdiman's Avatar
I'll look for one online to buy
Old July 27th, 2020, 14:55   #11
tdiman
tdiman's Avatar
Default Valve cover
After clearing /resetting Glow plug light a few times light went off and engine light came on don’t understand that so took car to Vw dealer they diagnosed valve cover gasket need replaced Vw of North America to replace and pay for repair. Anyone else have this problem yet ?
Old July 31st, 2020, 14:04   #12
JackEnrod
Technology is not always an improvement.
JackEnrod is offline   Reply With Quote
Code 17057 - cyl 3 glow plug and glow light on for half sec gone postal VW MKIV-A4 TDIs (VE and PD) 3 October 21st, 2014 12:16
Check Engine Light and Glow Plug (?) Light appearance in 2002 Jetta JGJetta TDI 101 4 September 15th, 2014 08:49
Where to plug in the wire to feed the glow plug light bbob203 TDI Conversions 5 November 19th, 2013 13:54
After battery replacement, check engine light on, glow plug light flashing ... redluv VW MKIV-A4 TDIs (VE and PD) 7 June 28th, 2011 10:59
P0571 Brake light switch code Glow plug light flashing andoo VW MKIV-A4 TDIs (VE and PD) 1 January 16th, 2007 11:23
Page generated in 0.14141 seconds with 13 queries
[Output: 107.39 Kb. compressed to 90.15 Kb. by saving 17.24 Kb. (16.06%)]
