This is supposed to be: "I'll show you mine, you show me yours." It is not for commercial use to promote any vendor's product(s). If you are going to advertise, do it on the proper forum.
When the commercial interests have posted pictures, they are evasive and don't show anything of value to promote the purpose of this topic. We are talking port design. As far as I can see, the commercial interests are not contributing much within the purpose of this thead.
Port shape is what this is all about. There are some obvious things that are necessary to improve porting design and much of this is purely logical. After all, when a cylinder head is so 'commercial' in it's approach, with a bottlenecks in the exhaust runners and restrictions in the swirl chamber is so obvious, common sense dictates improvements.
The word 'phenomenon' indicates that the solution is not understood or does not follow conventional wisdom. The reality is there is a solution, but it is not presented. I listened as well as watched that video, Marko. There are some very strange sucking noises going on. I think the correction is apparent.
Also, there is not 'perfect' solution, but only compromises. Valve guides are too short, intake porting has potential for cracking, mis-match to exhaust can be as much a 1/4" off, bolt holes are intruding best flow angles, water jackets are too close...and all of these require modifying designs to balance pure flow against cylinder head design insufficiency.
All in all, we have no complaints from customers with the improvements we have made. As a matter of fact, most complaints come from competitors who haven't even seen or applied our work. We are okay with that.
We have worked with another well-known porter, Matt Whitbead. When examining each other's work, we found that what each of us, individually, found improvements which are very identifiable in each other's work. There are bottlenecks and rakish inside turns. Do the obvious and improvements are there.
The biggest issue... we find so many builders are wanting design extremes, then want to see if we can 'keep up'. Questions like, "What does your cam dyno?", "Can you make the engine produce 300hp?", "How much larger a valve can I install?"... When the design purpose of the engine is fuel efficiency and longevity. All of these requests are outside the intended design parameters of the engine. Our goal was to improve the engine within it's limitations. That does not dyno well.
But when you get enough practice and find over your historic builds that engines show improved fuel economy AND improved hp, we feel that is the right path. We are trying to optimize, not maximize, the purpose of the engine. We are working toward different goals. We do not require 12mm lift to create performance, as that is detrimental to the cam/ cam follower life-expectancy. The same is true for excessively increasing boost pressure, valve size, piston size, injectors, valve springs, etc, all of those 'improvements' increase strain and reduce engine life.
Our main focus is not to create race cars, but to optimize the engine for a very street-able vehicle with long life expectancy. As it turns out, that is the goal of the largest segment of TDI owners. We hope to provide that segment with designs for a sustainable engine that will get reasonable performance gains while maintaining longevity.
