Mark@MaloneTuning
Vendor , w/Business number
- Joined
- Sep 24, 2003
- TDI
- '14 GSW TDI, '11 Golf TDI, '97 Golf Variant Syncro 1.9L TDI, '96 Golf 1.9L ASV TDI, '93 Eurovan Westfalia 1.9L TDI, '09 BMW 335d, '17 BMW 328d
Bosch specifies 4800 RPM max. for PD injectors.
5200 RPM is too much, and 5000 RPM may be pushing it. Often you won't hear valve and piston contact, but if you take the head off you may see valve marks. I have seen a few highly modified PD TDIs with the valve marks.
4800 RPM is a reasonable limit for most PD engines, but some clients want more. Given that good power can be made at 5000-6000 RPM with good airflow (especially with nitrous oxide), it's understandably hard to resist.
