Sharan/Galaxy Mk2 - Driveshaft spring
Audiman
Leicester, UK
A4, 2000, Silver
I've just changed the intermediate drive shaft which goes to the transmission\diff.
What's the best way to compress the spring - so I can tighten the bolt
Any pictures would be appreciated
mr.loops
Kelowna
2002 jetta, 2003 Bora 1.8T
I’m assuming you have a 020 trans
You will need a tool similar to this to compress the DF in order to get the c-clip onto the stub axle ( or make your own)
Audiman
Leicester, UK
A4, 2000, Silver
I don't think that's the correct tool - that's used on the old style VW to press and insert the circlip.
For the Sharan/Galaxy Zetec 2003 TDI 6 speed - both have to same setup. You need something to press the outer housing and hold it down, then insert a threaded bolt in the middle and tighten.
I'm trying to use a bearing press and press against the anti-roll bar - will try it tommorrow.
mr.loops
Kelowna
Sorry I saw the mk2 in your OP so I was assuming you had the older 020 trans
The 03 should be the 02J box. These can be quite hard to press in, and as far as I know, VW does not make a tool for this step.
If the trans is still in the car, you should be able to use the K frame as a leverage point to press in the drive flange while tightening down the bolt.
If it’s out of the car, your going to be creative. I’ve used my 30 ton press to gently press it in
