I finally replaced my axles this weekend, and while I was under there, I clocked the center section/compressor housing just a little bit so that the turbo outlet hose would stop rubbing on the axle. I also replaced the turbo outlet hose (see post 43 - been driving with it like that for 2 years now).
And, while I was there, I decided I'd try and see if I could make the 17/22 actuator that I cobbled together work a little better (see post 2 for why I ended up doing this in the first place).
I was able to move the actuator "in" a little bit which helped the geometry. Same actuator and bracket, I just drilled another hole in the bracket which puts the actuator can more or less touching the compressor housing. Pretty simple, it used to be in the right hole, now it's in the left
This makes the actuator able to move the vanes farther since it's more perpendicular to the arm. Before it was only able to move the actuator 2/3 of it's travel and now I'd say it moves it ~90% of the travel.
Here it is full open
Here it is at full vacuum (~20inHg)
I wasn't quite sure where to set the actuator preload since it ran pretty well before and I was worried about really big EMP spikes with the vanes being able to close even further.
The actuator starts moving at ~5inHg (was a bit hard to tell since the vacuum pump I was using wasn't very good - had a leak in it so had to continuously pump it) and was at the end of it's travel by ~18inHg.
I was not prepared for how significant of a difference this made in almost every aspect of how the car drives and responds to throttle inputs. It was a more significant change than switching from a VNT15 to a VNT17/22. The turbo just does everything better* - it spools faster, it has lower EMP spikes and lower running EMP's both at low and high RPM's, it handles mid throttle transitions better. * The only compromise is that it's a bit smokier on tip in at low RPM - it used to get down to 14:1 or so if you got after it "under" the turbo, and now it's 10:1-12:1 which is pretty smokey. For reference, when I say low RPM I mean 1200-1400 RPM and more than 50% throttle suddenly applied. If you roll into it at low RPM's or stab it at 1800 RPM or above, it just takes off and pulls hard all the way until ~4000 RPM where the EMP's hit ~50 PSI and that's the end of my gauge.
I'm still running my RC6 tune for a 17/22 at this time - It's MAF based so it does a really good job of maintaining AFR levels regardless of ambient temps, turbo spool up, actuator settings, etc. Requested boost is pretty significant at low RPM's (I think this is to get the 17/22 spooled up?), but this smaller turbo will deliver those boost pressures and the N75 PID must be setup well enough that it works. It's definitely an experiment on my part, I just threw it in one day (see post 44) and it works really well and now it works even better with the actuator changes.
I'll try to get some VCDS boost logs to compare with the data in Post 3 and maybe a dyno curve to compare with Post 5, but it's really quick in terms of transient response - you touch the pedal and it's almost "right now" response. I've got a video that I need to get off my iPhone somehow and then I'll put it on YouTube and put a link here.
The actuator adjustment ended up being really easy - I wish I would have done it a couple years ago.
