WalkingDrunken
For the last 1,000 miles I've had what resembles a wheel bearing sound coming from the front of the vehicle. It is more pronounced on whichever side you sit on. The sound increases with speed and does not change with the clutch engaged or disengaged. It also does not change if you are on the throttle or brake or if you make a turn in one direction or another. I am probably paranoid but it seems like it is getting louder each time I drive.
No performance change, MPG has stayed consistent, wheels are not blazing hot after driving like I've experienced with a stuck rear parking cable, very very slight vibration felt through the car and steering wheel.
I have rotated the tires and replaced the driver side wheel bearing since that was the most pronounced location of the sound when I drove. I did not notice any change. Just to cover my bases I have the passenger side wheel bearing being delivered today. The car has been running Redline MTL for about 10,000 miles. I am swapping fluid tonight for OEM fluid.
I am having a hard time trying to diagnose the issue / the next step. I really need your guys help.
~70,000 Miles. Original DMF & clutch. Original Struts and springs. H&R sway bar, CP3, fluidampr.
EDIT: I found many cases of vibration on vwvortex due to axles. In my experience bad cv/axle has only caused clicking not a vibration. I'd be much happier to replace axles than DMF/Clutch/Rebuild tranny. Axle/CV is very hard to find for a 6-speed.
